Problem with Toshiba SD 2900KU dvd player
Our Toshiba sd 2900ku dvd player will **t power on. Power light flashes then goes off. I have unplugged it and plugged back in and ** effect. I have a CD in the player. Is there a way to remove it?
Thanks
4 Suggested Answers
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
Posted on Aug 30, 2008
jaffa012001
  • 376 Answers
SOURCE: un lock toshiba dvd sd-370 ekb
http://www.avforums.com/forums/showthread.php?t=508285
go down page until you see the download from here there are 2 file follow instuctions and it will work
Posted on Sep 09, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
When I plug the unit in and try to turn it on, nothing happens. toshiba sd-3980 dvd player
The internal fuse is blown.
It may be a replaceble glass cartridge fuse, or a fuse soldered to the power board.
Unplug, remove top cover, check and replace fuse. Radio Shack has reasonable coverage of fuses.
But - fuses usually blow for a reason. It could have been a power surge; it could be an internal failure. If the new fuse blows, it needs professional replair. Many of these are so cheap to make that it doesn't pay to repair them - replace it if the repair estimate is over 1/2 the replacement cost.
Nov 01, 2009 | Toshiba SD-3980 DVD Player
Toshiba SD-6000 dvd player tray will not open. The OPEN and LOAD lights just keep flashing.....is there a way i can reset it by unplugging it? it was working fine until now.
The tray is blocked or the drive motor is stucked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check the motor if it's trying to spin. if not, disconnect it and connect it to a 12-volt supply or lower. If it spins then there's a problem with it's supply. Otherwise the motor should be replaced.
Aug 06, 2009 | Toshiba SD-6000
Dvd player shuts off during movie
Look at the power supply capacitors to see id any have a bulged top. Those need to be replaced.
Sep 03, 2017 | Toshiba SD-2705 Multi-disc DVD Player
Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 20, 2008 | Toshiba SD-3960 DVD Player
Toshiba SD-220E
Have you tried unplugging the player completly for 2 minutes? Plug it back in and try again. Also, you could try a new remote code or just replacing the system. P.S. some players have a cap/switch or button that needs to be removed or pushed in order to accept input.
Feb 08, 2007 | Toshiba SD-220E DVD Player
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
