BOSCH Washing Machine -Door Seal
Need advice on how to replace the door seal on a Bosch washing machine WFO2464GB/01.
  • 4 more comments
  • norman417 Jun 15, 2008
    TY - unfortunately as helpful as your answer was, time was of the essence and I had to tear into it myself. Your method works - if I had your advice I may have done it in half the time and with less fear that I was going to break something. Thanks for replying though. :-)
  • jrm1053 Jul 22, 2008
    I have a Nexxt 300 I came home and found what looks like the retainer spring / ring sitting on top of the washer. I have no idea or diagram where it goes or the steps to get it back in place. (gotta love your daughter:>)
  • bobcrawford Oct 22, 2008
    Anyone help with how to replace the door seal pn a Bosch WAA20160GB washing machine. Do I need to remove the front of the machine??
    Any help appreciated.
    Thanks
  • debbyrolls Jan 06, 2009
    i need to replace the door seal on a WFL 2060. i did look and found the spring.
    there is only a small rip...can i just put silicone into the hole and seal it that way?
  • Anonymous Mar 21, 2009
    i took the rubber out of the door and cant get it back in
  • Anonymous Mar 20, 2014
    Changing door seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Posted on May 23, 2008
  • Washing Mach... Master
  • 744 Answers
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Posted on Jul 19, 2013
Mcpcis was right. simple as that. i did have to remove the door (3 screws) only because my arm is sore and i needed more room. it only took 20 min. thank you for the easy instructions
Posted on Jan 14, 2009
Hi
i have a bosch waa24160gb/1 washing machine, are they the same, only i need to change door seal, cheers
Posted on Aug 03, 2008
How to replace door seal on washing machine Bosch Advantixx ?
How to Replace the Door Seal on a Washing Machine - Bosch
One of the most common faults of a leaking washing machine is a faulty seal. Thankfully replacing such a component of your washing machine is not a difficult task.
In the above video, with the help of our experienced team, we explain how to replace the washing machine door seal, and below we've compiled a simple step-by-step guide which takes you through every point covered in our video.
Step 1: To remove the door seal on any make and model of washing machine, you'll need to remove the entire front panel, followed by the soap dispenser and fascia.
Removing the panel and fascia is easy to do, once you've undone the screws holding it in place, whilst the soap dispenser should just clip out of place.
Step 2: With these components removed, clip away the kick plate, put the drain hose to one side before removing the retaining clip which holds the door seal against the front of the machine. Once the clip has been removed just push the seal inside.
Step 3: Undo the four remaining screws holding the front of the machine on, before pulling the front of the machine and the door away from the machine.
Once the front of the machine is off, you should be able to see the spring retaining band going all the way around thedrum. This should be easy to pull off, enabling you to peal the whole old seal away; once you've removed the old seal this can be thrown away, although it is advisable to keep the retaining band, as this can be reused with the new seal.
Step 4: You'll now be ready to attach the new seal, when doing so make sure that the drain holes are positioned at six o'clock; once you've done this it is just a case of working the new seal onto the drum.
With the seal worked onto the drum, put the retaining spring into its little ridge, before giving the seal one final check.
Step 5: Reattach all the parts back to your washing machine, attaching the door seal to the front of the machine ensuring that it goes over the lip, before attaching the retaining band on the bottom and sides.
There you have it, a step-by-step guide to replacing the door seal on a washing machine, helping it to perform to its optimum level.
SAJID
How to Replace the Door Seal on Washing Machine Bosch
Feb 17, 2016 | Bosch Washing Machines
How do I clean the rubber door seal
This video will show you how to change a door seal on this bosch
Jun 26, 2012 | Bosch Washing Machines
Door leaking
This video will show you how to change a door seal on this Bosch front loader washing machine
Dec 21, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
I want to replace the door seal
Jun 01, 2009 | Bosch Washing Machines
Fitting washing machine boot gasket/door seal
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fixing new rubber door seal to bosch washing machine
have Maxx bosch machine trying to replace robber door seal. Can you advice how to do this as having difficulty with spring retainers
May 16, 2008 | Washing Machines
Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
May 13, 2008 | Washing Machines
Replacement door seal/gasket
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
2,684 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
