Question about Microwave Ovens
Looking for replacement grilling surface plates for grill. the top plates reads TSK-2612#1 as does the bottom.
  • 1 more comment
  • Anonymous Jun 12, 2008
    i dropped the top plate and broke handle need new replacement plate #2 which is the top.. if anyone has one, pls let me know. Tks
  • g071 Sep 07, 2008
    I need the same plate for my Foreman grill which looks as though the teflon has rubbed off. Any ideas out there?
  • William Miller
    William Miller May 11, 2010
    If you can reply back with your brand name and model, we may be able to help.
THENTHEREWER
  • 131 Answers
SOURCE: need a glass tray for sylvania
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY THIS IS THE ONLY PLACE I COULD FIND THE PART YOU ASKED FOR ,JUST COPY & PASTE THIS INTO YOUR BROWSER & YOUR THERE.YOUR MODEL # DOES'NT SEEM TO BE COMPLETE,THERE ARE LIKE 2 OR 3 DIFFERANT PREFIXES FOR YOUR MODEL.SURF THE SITE,ITS PRETTY SIMPLE.ITS A LITTLE PRICY,(62$)BUT I DID MY BEST,HOPE THIS HELPS!!!
Posted on Nov 08, 2008
  • 86 Answers
SOURCE: Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Posted on Dec 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: looking to buy a top vent grille
Depends on the brand, but you can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If not, Please reply back with your brand and model number so we can help you.
Posted on Feb 14, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: jvm2070sh001 microwave problems: the top grill was
The top grill problem is probably due to the grille's being broken.
There are switches associated with the grille door and if they or their actuators are damaged, it can make the grille motor want to come on (or not come on) when it should (or should not).
This exploded view diagram shows where they are.
The turning off after cooking for 2-3 seconds is a bad magnetron. See this FixYa solution even though your model number is different.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 05, 2010
  • 8909 Answers
SOURCE: there was a bright light
Carbonised food build up or a metalic object was in the cavity as it was being used, causing internal arcing inside the food cavity. You may find the cover over the magnetron aerial is blackened. If it is change it.
Clean the oven cavity and check for damage.
Hope that helps.
Posted on Dec 11, 2010
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Need instructions to replace fuse
First unplug the microwave, then remove 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, or tilt out the top of it followed by the bottom. Now you should see 1 screw that holds the top of the control console in place. Remove it, then lift up on the control console to free it past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 30, 2014 | Whirlpool Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Grilling bulb out
hello chris microwave is an american model
I found the tube/bulb you looking for is like the picture and called quartz grill tube and can be replace by similar voltage 120 v
Apr 01, 2014 | Whirlpool GH6177XPS Microwave Oven
I need to know how to put the kick plate back on
Hi mstweet22.
Could you supply a make, model, and serial number taken right off of the unit (not the book). A kickplate is the bottom grill on a refrigerator, but you state it's a microwave. Do you mean the vent grill across the top of a microwave?
If you would supply that info, I can get a picture up and help you.
Let me know.
fil
Mar 03, 2011 | Hotpoint Microwave Ovens
How to change the light bulb?
depends on what light your talking about.. if it is the surface light under microwave if this is a cabinet mount you will have to remove the screws normally phillip head under unit adn swing down the bottom plate to access... if your talking about the light in the microwave depending on the brand you may have to take the top cover off which sometimes is screwed coming down from the top or if you look through the luvers of the grill cover will have a couple of phillips screws once removed alot of them you can access from that area.. some even have a cover inside the actually microwave you remonve but should be very visible just by looking if this was the case... if all that fails the only way to change on certain models unfortunately is to take exterior shell off and sccess that way.. simple process just time consuming... good luck to you ///microwaves gotta love um work on these things on a daily bases and they can be fun....
Dec 31, 2010 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Nov 15, 2008 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
206 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
