Question about Vacuums
Hoover Wind Tunnel
My NEW Hoover 'Wind Tunnel # U 6637-960 will **t work more than 20 minutes before the flat belt slides off the top pulley. Got new belts from Sears - ** help
  • 4 more comments
  • Rich14 Mar 15, 2008
    Put on a "OEM" belt - will try it on monday - repair people say that this cleaner will not work on "after market" belts
    Glad my car does not have this stupid FLAT pully system for the belts,- no groves, no guides. I would never make it out of the driveway!!!
    Design flaw (In my opinion)
  • Rich14 Mar 16, 2008
    Tomorrow is cleaning day - let's see how the OEM belt works - if it comes off - to the shop it goes- a 1 hour drive!
    (Flat belt - flat pulleys, no guides -WHAT were they thinking - ?DAH)
  • Rich14 Mar 22, 2008
    Nope - OEM -Hoover belt no improvment _ did about 1000 sq ft of carpet before it poped off the pulley
  • jim0763 Nov 16, 2008
    I have put both hoover belts and after market belts on and it just tosses them off instantly. It all started when the large pulley came off the shaft. Put it back and tightened it down. Put new hoover belts on, ran for about 5 minutes, then threw a belt. During that time, the sweeper seemed to be moving faster than ususal in self- propelled mode. Now any belt gets tossed instantly.
  • Anonymous Apr 25, 2009
    I have the canister windtunnel, and the belt continues to fly off. It seems like that would be an easy problem to fix or part to add, but apparently it's a common issue. I didn't expect this from a $200 vacuum.
  • Anonymous Mar 17, 2014
    How do you change the belt on a Hoover wind tunnel vacumn?
    President:
  • 1,673 Answers
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Posted on Mar 11, 2008
  • Lauren Junge
    Lauren Junge Mar 15, 2008
    May work ok or it will keep coming off, the proper belt works better.
I have a hoover wind tunnel model# u6476-900 and I'm having trouble replacing the belt. The extra belt that came with it was belt # 38528-035 and it's smaller then the old one and I'm having a hard time...
yes it is the right belt. the easiest way to get that belt on is to put it on the motor shaft first, stretch and start at the top of the self propelled pulley and rotate til the belt tracks on. you will need to keep pressure on the belt while you rotate the pulley. make sure you install the 38528-034 first before the flat belt
Jan 07, 2010 | Hoover U6476-900 WindTunnel Vacuum
Replacing a belt Hoover wind tunnel
You will find four screws under the bottom cover. remove these. remove the beater bar, loop new belt on bar on pulley area. install the bar and then pull the belt over the motor shaft. re-install cover.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 05, 2009 | Hoover Vacuums
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
New belt won't stay on
take it in for diagnosis - seems to be an offset perpenducular drive axis.. seems to me.
May 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Wind Tunnel V-Belt no longer turns brush
that is the correct belt what you dont see is a tension pulley that when the handle is released pushes on top of that belt giving it the tension it needs. try replacing the other belt, even if it isnt broken it could easily be stretched out ( all belts of that type should be replaced every year - even if you didnt use the machine at all ). if that doesnt work that tension pulley could be damaged you would need to take the bottom of the machine apart to fix that.
Sep 18, 2008 | Hoover U6311-930 Power Drive Bagged...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
Flat belt to hard to stretch
The belt number is 38528035 and it will stretch far enough to go over the bigger pulley.
May 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Sep 02, 2007 | Hoover Ultra U6430-900 WindTunnel Bagged...
Vacuums Logo
185 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
