Question about AsanteTalk - Ethernet to LocalTalk Adapter Transceiver
Asante Talk doesn't see printer after power failure
I realize this question sounds like one already asked, but assuming that I am reading your instructions correctly, I'm still having problems.
I have an old HP Laserjet 5MP that I've been using the Asante Talk with for over 5 years. Every time we have a power failure, I go through a routine to get the Mac that my wife uses to see the printer, which has an Apple Talk port but ** USB ports.
After this last power failure that we had (Saturday after**on) I have been unable to get the Mac to print from the HP.
I have tried the following sequences:
1. powered down everything; turned on the printer; turned on the Mac; turned on the Asante. -- Not able to print.
2. powered down everything; turned on the printer; turned on the Asante; then turned on the Mac -- Not able to print.
It was working fine before the power outage and, as I mentioned above, I have been able to restart things properly before when there as a power outage. From the sticky **te I made for the purpose, I expected situation 1 to work for me,.
My configuration is simple: ethernet from Mac to Asante; Local talk connector from Asante to printer. (I also have a PC hooked in directly to the large parallel port via a standard cable. I have **t had to power down my PC at any point in the past to get the Asante switch to work properly.)
For **w all I can think of doing is to try to repeat situation 1 or 2 or come up with some variation and see if anything works.
Can you provide any other guidance? Thanks.
  • 5 Answers
The Asante tech support people in San Jose, CA, talked me through this fix, and I've had no further problems!
This is for system 10.5.x:
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully now.
Posted on Jan 17, 2009
  • patm-r May 23, 2011
    Many thanks for this solution — and it worked!!! And in May 2011 yet with both an Intel iMac and a G4 MDD all networked.
    I had tried all the shut down and power up 'reset' stuff and nothing worked to get our old HP 4ML Appletalk printer working again as it did just just a few days ago. Then for some reason it wouldn't print today and I was suspecting the Asante Asastetalk adapter as the cause.
    I found this when Googling for some method or how to test the Asantetalk adapter.
    A bit of a bizarrre method but it did work using our Intel iMac in 10.5.8 as the G4 MDD doesn't have Bluetooth. The HP 4ML is now available and shareable with all our networked Macs, including 10.6.x when the HP Laserjet is shared from the running G4 MDD that's acting as a print server.
    What a relief for a fix and any thanks for the "method" fix.
  • trooster Jun 01, 2011
    This is Trooster again, source of the original "Solution".
    My power was turned off a few months ago, and I actually became confused by my own instructions when trying to re-establish communication; when my "fix" didn't work, I called Asante in a panic. (Who wouldn't panic ... these old HP printers are the best!)
    I had the situation fixed by the time the Asante guy phoned me back, about 20 minutes later, but the reason I mention this is that you should feel free to phone Asante if you're still having problems: 408-435-8388 ext 521, or 877-262-0324. They've been wonderful each time I've needed them.
    I don't think simply turning the equipment on and off will do much of anything. I encourage you to follow these simple instructions, and you should have no problem after that:
    1. In System Preferences, choose "Print & Fax," highlight your HP5MP, then click the minus sign to delete the printer.
    2. Make sure everything (computer, printer, and Asante box) is connected and turned on.
    3. Once again open System Preferences, choose "Print & Fax," click the plus sign to add a new printer, and click once on "Apple Talk" in the top row of options.
    4. After a few seconds or so, click once on "Bluetooth" in the top row of options.
    5. Unplug the thin black Asante power cord from the Asante box but DON'T unplug the Asante power cord from the wall socket.
    6. After a few seconds or so, plug the thin black Asante cord back into the Asante box; then as quickly as possible after the "TX" light blinks once, click once on "Apple Talk" again.
    7. After a moment, HP5MP should appear across from "Local Talk." Click your printer's name to highlight it, make sure all the information in all 3 rows is correct, then click "Add."
    Good Luck.
Wrong cartridge : i m asked to replace the with the original ink cartridge that was shipped together when first purhase the printer. The problem is they were already thrown away after used. my...
The printer is asking for the original type of cartridge HP 02 assuming the current cartridge is a different type.
These instructions may also help:
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
May 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
R@hotmail.co.ukplease show where to plug laptop into printer
The 5P has connections in the back of the printer, left hand side, under a removable panel. The power plug is under a similar panel on the right side. (as you face the printer from the front) There are connections for appletalk and serial under that left panel but not USB. If you want to use this printer with a modern computer you will have to work from either a serial port or an ethernet converter such as the Asante. Plug the ethernet into your router or RJ 45 jack on the computer and on the Asante. Plug appletalk from the round connector on the Assante into the HP 5P. NOTE: The 5p will not work with a Mac. The 5MP printer will.
Mar 25, 2011 | HP LaserJet 5p Printer
Code 0xc18a0201 problem comes up. What do I do?
I found this solution for a C5180 Ink System Failure....and assumed/hoped the firmware was the same....it worked!!
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Please dont forget to rate me.....Thanks.....
Feb 04, 2011 | Office Equipment & Supplies
Laser writer select 360 to Mac OS X 10.4.11 via AsanteTalk
You should phone the Asante tech support people in San Jose, CA, who will talk you through the fix for free. I lost my printer-MacPro connection, the other day, and everything works fine now, thanks to their advice.
I'm running 10.5.x and no WiFi so the fix may not be the same, but it was just a matter of sort of re-booting the Asante box. Here was my fix, if that helps:
9. Everything should communicate beautifully. I had no further problems.
Dec 21, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Asant? Talk compatibility with Mac OS 10.5.5
Nov 13, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Laserwriter 4/600 to G5 via asante talk
The wonderful Asante tech support people in San Jose, CA, talked me through this fix last week:
This is for system 10.5.x.
Sep 06, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Networking
each switch need to plug into the router where they get dhcp I am assuming these are unmanaged switches
Apr 17, 2017 | Asante FriendlyNET FH10T5 (99-00418-01)...
Same issue after power loss...
The wonderful Asante tech support people talked me through this fix (for free), just the other day.
Jun 25, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Lost Connection
Asante Networks, Inc. 2223 Oakland Road, San Jose, CA 95131 USA Phone 408.435.8388 · Website www.asante.com Asante Networks, Inc. 2223 Oakland Road, San Jose, CA 95131 USA · Phone 408.435.8388 · Website www.asante.com i assume you have tried to get into the router settings, if not, this is how, Make sure you typed in the address correctly. (Default: 192.168.123.254) Add http:// in front of the address. Try http://192.168.123.254:88. Make sure the link light on the front panel is on for the port you are plugged into. (If it is not, you have a bad cable, wrong type of cable, have not seated the cable well, or have a problem with your computer's ethernet adapter card.) Make sure the router is plugged in and on. Make sure your computer is set to DHCP (Mac) or Obtain IP address automatically (PC) in the Network control panel. If you can configure the router and the router can receive a proper response and IP assignment from your ISP, then you are connected to the Internet. If you are unable to browse or other such operations it is almost always because your DNS (Domain Name Server) setup is incorrect. Check both in the client computer IP setup as well as the router setup to make sure that your Domain Name Server is one that can be reached and pinged. if you need to reset the router because you've had no response, reset the router by unplugging it, waiting 10 seconds, then re-plugging it. Restart your computer. If you still are unable to get on the net, then either your isp is at fault, so check with them for a network status, or the router may be faulty.
Jun 06, 2007 | Asante FriendlyNET FR3004LC (99-00618-91)...
Open Questions:
24X7 Free availability and assistance for toshiba support. Are you witnessing issues in your Toshiba laptop like your laptop isn't working since you installed an app, driver or update? Many Toshiba laptop and pc users report issues they face in their day to day life. Toshiba technical support is always available to help customers confront such situations and resolve issues for better working laptops and their longer productive lives. In case your Toshiba laptop is not letting you peacefully open the start menu or you are facing troubles installing any update or your newly installed update is not working the way it was supposed to then this article will help you in getting all the right answers for your issues. Toshiba support email is always available to help its customers at any time of the day and they even provide on-site support facilities. Toshiba support is provided by experienced and professional technicians who use industry authorized advanced technical tools and techniques to cater fully effective measures used to counter all possible issues that interrupt the productive working of Toshiba devices. In case you are facing issues in your Toshiba laptop you simply call our Toshiba laptop support , you can find out the cause of those issues by restarting your pc in the safe mode. Taking this option will remove all those apps, drivers and updates you have installed after the restore point was created but nothing will happen to your personal files. For using the restore point, you have to go to the control panel and type recovery in the search bar of control panel window. After that you have to choose the option of open system restore and click on next. You have to then select the most recent apps, drivers and update and click on the option of scan for affected programs. You can always contact Toshiba customer support using their toll-free helpline number +1888784-9316. They will provide on-site and on-line support assistance over the phone, email or chat. If restoring from the restore point doesn't help then you can reset your pc and wait for issues to get resolved. Resetting results in reinstalling of Windows after choosing which files you want to keep or remove. Resetting option is available in the settings menu. Under the sub section of update and security, there will be the option of recovery which will further have an option of reset this pc. For assistance in technical issues you can contact Toshiba customer care anytime.
Sep 24, 2018 | Toshiba Computers & Internet
See all AsanteTalk - Ethernet to LocalTalk Adapter Questions
AsanteTalk - Ethernet to LocalTalk Adapter Transceiver Logo
709 people viewed this question
Top Asante Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Asante Computer and Internet Expert? Answer questions, earn points and help others
