Question about Dryers
Removing front panel on kenmore dryer
Home model number 110.66732500 electric clothes dryer is not heating so i purchased all of the parts that make it heat. this model is accessable by removing the front panel. i need to know how to get to the bottom screws that hold the front panel on. can anyone help? thankyou
  • Anonymous Mar 23, 2014
    Removing front panel for heater replacement
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
Dryer works but want get hot to dry colthes
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
IMPORTANT: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Again, begin by verifying the source voltage at the receptacle and service breaker, and verify your power cord.
The reason a dryer may still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel. The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals (all the way towards the back of the dryer cabinet). The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
NOTE: If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If you have questions, or require additional assistance, please post back with a MODEL NUMBER and let me know. I hope this helps you.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Apr 25, 2011 | Kenmore Dryers
Have a Kenmore Model 80 Electric home clothes dryer and it won't start and light won't turn on. It is about 8yrs old. Checked breaker and still no power. Is it likely thermal fuse? If yes, where/what is...
Yes that would definitely be a thermal fuse problem. Take the rear panel off your dryer and look down at the lower left where the blower housing assembly is there will be a white rectangle looking thermostat with 2 blue wires going to it that is your thermal fuse. Unplug the 2 blue wires and then you will have to remove the screw which will be a phillips head or 1/4 bolt then the thermal fuse will slide out you need the model number off the dryer which is located on the top left of the dryer behind the door take that to your local appliance parts store which they carry that in stock and just replace using the same steps above.
Jan 04, 2011 | Kenmore Dryers
My kenmore dryer wont get hot... I got the proper voltage, what can it be?
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If your ELECTRIC dryer is running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
Replacement parts (if required) may be found at the following websites:
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
NOTE: The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information is helpful.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Aug 07, 2010 | Kenmore 700 6972 Dryer
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
I've just purchased a used dryer, and unfortunately it makes a steady whining noise while it's running. It's driving me nuts.
sounds like youhave something in the blower wheel. if your dryer has a front removable lower panel with a putty knife on the left and right sides 1 inch in from the sides slide putty knife in to release catches. two screws hold the bower housing on then you can look at blower wheel. if it doesnt have removable panel then youmust access it from the back access panel then on left side take out 4 srews that hold blower cover on and pull back as far as youcan without bending top and look inside with a flashlight.. remember always unplug unit
May 27, 2009 | Whirlpool LEQ9858L Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Kenmore Elite model 110.63932101
There is a sensor bar usually two on the inside of the dryer either in the front where the lint trap is or in the back right corner u will have to take the machine apart to ensure that the wire is firmly connected to thsoe sensor bars that would be the first thing i would recommend u check symptoms are itruns for about ten minutes and cuts off and clothes are still damp but time cycle works fine.
Mar 19, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
671 people viewed this question
Top Dryers Experts
