Question about Gateway FPD2275W LCD Monitor
Lcd screen how can I brighten my screen on my 5610 laptop
  • Anonymous Nov 26, 2008
    hello! I have dell inspiron 8600 and would like to know a solution please,,, as I tried the Fn >< no go thanks ahead
    ps. I could ask dell I know, but this format is so easy and comfortable to ask the all knowing!
    h
  • 807 Answers
Brightness controls are usually on the keyboarb using the Fn key and another key. Depends which make of laptop it is.
If it's an Acer Aspire then it's Fn + right > to increase brightness and Fn + Left < to decrease.
Posted on Mar 09, 2008
  • Stuart
    Stuart Mar 09, 2008
    Edit:
    < and > means arrow keys.
Hiw do i brighten the Lcd screen on quantum xl 100
hi kate,
this link will take you to the manuals your one might be there,this is all i could find at the mo.
How do brighten the Lcd screen on quantum xl 100 manual Google Search
or this link.
How do brighten the Lcd screen on quantum xl 100 Google Search
Nov 03, 2017 | Sewing Machines
My brightness is low and i want to increase it
just keep looking at F1 to F12.there you will see a symbol like Sun .probably it will be Dark sun and brighten sun.while keep pressing Fn key press that Brighten Sun key.screen brightness will be increased .if it is already Full,Screen back light or Inverter circuit is defective
Jun 13, 2011 | Toshiba TECRA 8100 (1024 X 768) XGA 14.1...
Hi i cannot adjust the brightness on acer aspire 5610, using windows 7 can you help me pls
Hi
I have an acer 5630 and my brightness key is over on the far right bottom side of my keyboard 2 keys for brightness and 2 keys for the volume
and i hold down the Fn key down on the bottom left of my keyboard as well as the brightness up key that should brighten your screen for you i hope it works for me
and the same for the volume
Nov 14, 2010 | Acer Aspire 5610 Notebook
Screen will not brighten
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 05, 2010 | Dell Computers & Internet
Screen dim;;; How do I brighten picture on screen? Have ACER aspire 5610
On your model, it looks like it is Fn + Left Arrow. Hold down the Fn key and them press the left arrow a few times to your desired brightness.
Jul 21, 2010 | Acer Aspire 5610-4648 Notebook
5610 lcd screen goes to a crazy pattern at times. It does not happen on a lcd monitor connected to the monitor port.
Patterns and lines are indicative of an impending screen failure or a loosening of the flat data cable on the back of the display.
Jan 04, 2010 | Acer Aspire 5610-4648 Notebook
The screen on my Toshiba satellite p205 went dark on me i check and u can see the window but really dark i replace the lcd screen and the problem persist help please what can the problem be my video...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 24, 2009 | Toshiba Satellite P205-S7806 Laptop
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 5610
If u check your keyboard you'll notice there's a button marked 'fn' , might be in a different color,now if you look good you'll notice a little star object usually on the left and right arrow key,now to use this additional function u need to press and hold the 'fn' button then to adjust the brightness press the right arrow key until seem fit or the left to adjust.
Feb 26, 2008 | Acer Aspire 5610-4648 Notebook
Gateway FPD2275W LCD Monitor Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
