Question about Dryers
Dryer does **t heat up. I have replaced the thermal fuse once and that fixed the probem and everything was ok for about two months. Recently, it started to act up again and I replaced the thermal fuse again, but ** heat. I next, decide to check the vents and confirmed their was ** blokage. I, by chance happened to turn on the dryer and gues what? Heat on all cycles. I am stumped by this, due to the fact that their is ** obstruction in the venting system. I am using a 4" ducting system in a vertical position about 8' long. Do you have any ideas as to what the heck is going on?
    Novelist:
  • 131 Answers
If you blow two thermal fuses in a year, replace the operating thermostat. If this is a gas dryer with intermittent heating problems, you might need a pair of gas valve coils.
Posted on Mar 10, 2008
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer runs but no heat comes out , I replaced the 2 termosat's but still no heat . the power level is ok 240 volts
Hello there
Thanks for using fixya
Ok there are 5 areas that need to be looked into 1 of which you have already changed over and over so you know it is not the heating element so i dont have to post that part so here is the rest
thermal Fuse
picture below
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Jan 24, 2011 | Whirlpool LEQ8000JQ Electric Dryer
Dryer runs but does not heat replaced the heating element a few months ago and fuses breaker box is good
hello there:
Please follow this troubleshooting guide that i will provide below
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
Thermostat
Timer motor
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Jan 25, 2010 | Dryers
Dryer will not heat up when running. Was told to check the thermo fuse, ignitor and/or coil. Is that right? How do I check those things.
hello there
Please follow this procedure I have provided below and it will tell you how to test each one ok
Hope this is very helpful
Proper Voltage
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Jan 24, 2010 | Kenmore Dryers
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
Dryer will not heat up, why?
Hello there
There are several reasons why a dryer will not heat up
i will do my best to explain them and i will add some links that you can use to help you out ok ?
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irreparable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Thermal fuse keeps blowing
You see the other switches next to the thermal fuse? you need to change these too if you have a problem with the themal fuse blowing out repeatedly.
Aug 09, 2008 | Kenmore 64902 Electric Dryer
Dryer stops after a while
it's over-heating it needs to be looked at, thermal fuses, lint buildup
Mar 24, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
179 people viewed this question
Top Dryers Experts
Marvin
Marvin
