VHS TO CD NOT COMPATIBLE
COPIED VHS TO CD AND THEY WILL ONLY PLAY IN THE PLAYER i RECORDED IT ON ** I CAN'T PLAY THE CD'S ON ANY OTHER PLAYER
  • TQUATRINI Mar 10, 2008
    I burned the VHS tape on to CD -RW disks.
    I did finalize the disks and I was hoping there was some reader I could use to move the data off the cd's on to a more compatible format that I could play the disks on other players..
  • 807 Answers
Do you mean DVD or CD. Some DVD players won't play CD Videos.
If it's on a DVD then maybe you need to finalize the disk.
That means ** further recording on that disk but it will be more compatible with other players.
Posted on Mar 09, 2008
Just a question? a samsung dvd v1000 can it burn cd,s or is it just a player?
DVD player only.
User manual: http://www.samsung.com/us/support/downloads/DVD-V1000
Product Features and Technical Details Product Features
  • DVD player and 4-head VCR, compatible with S-VHS, VCDs, CD-R, and MP3 audio
  • 400x speed rewind; 16-event/1-year timer recording; records non-copy-protected DVD to VHS
  • Component-video, composite-video, and S-video outputs offer optimal connection with compatible DVD player
  • Virtual surround sound simulates 5-speaker sound using only 2 speakers; DTS digital output for DTS-enhanced DVDs
  • Measures 17 x 4 x 14.3 inches (W x H x D)
Technical Details
  • Brand Name: Samsung
  • Model: OUTLET-DVDV1000
  • DVD Type: DVD player
  • Parental Lock: Y
  • Audio Output Mode: Stereo
  • DVD Media Loading: Tray
  • Width: 17 inches
  • Depth: 14.3 inches
  • Height: 4 inches
  • Weight: 12.3 pounds
Apr 15, 2011 | Samsung Televison & Video
Trying to copy VHS to Disc-Says"Unknown disc"
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
I have Toshiba D-VR660KU, I've copied several VHS
you need to finalize the disc or "make compatable" or "close session". basically the disc needs to be finished off to be able to play on any dvd player. dvd-r will normally play on any player as it is the standard format dvd discs. dvd+r/rw discs do not need to be finalized, but don't play on all machines.
May 22, 2010 | Toshiba D-VR4 DVD Recorder/VCR
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
PD DVR100
Hi again,
This is a placeholder and would look forward to the diagrams.
Cheers.
Jul 28, 2008 | Protron PD-DVR100 DVD Recorder
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
Can''t play dvd-r on my computer
Is it the DVD player/cd burner combo on your computer or simple CD player?
Or
Compatibility: Check if your DVD player on your computer is compatible of playing -r's CD or DVD?.
Check the make and model of your computer and go to the manufacturer's website and find out from there.
Or
You might have to talk to the manufacturer's support.
and if you are sure that the DVD player and its compatible of playing -r's DVDs then first of all check by playing any +r's DVD and see how they respond. If you are certain that it plays - and +rs etc then recheck your recording of DVD's.
Also try installing a good program software like Nero on the computer which will give you options of controlling, burning and playing DVD/CD on your computer.
Best of luck!
Dec 09, 2007 | Computers & Internet
New Unit- Plays VHS - Plays CD - All DVD's say - No Read -
you are trying to play dvds you have recorded on a different player and because you recorded them onto RW discs they have not and cannot be finalized, to be made compatible to play on other makes of player.
Nov 30, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Feb 01, 2007 | Daewoo DVRS05 DVD Recorder/VCR
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
