Question about Logitech X-530 Computer Speakers
My speaker that controls volume
Can I buy and individual speaker for th x-530
my control speaker tha controls the volume of the entire speaker system has broken
i need one speaker
the one that has the on and off button and the volume button
please call me at 510 290 5441
or email me at tbanks102002@yahoo.com
thanks
  • 34 Answers
Probably not but if you could try checking e-bay or the offical website of your product. I don't know because you didn't mention the brand. Check freecycle.org to try and get a used one free that someone else near you may not want. It is a stretch and is not likely but maybe...
Posted on Mar 10, 2008
I did some thing nd my speakers are not working
you might muted your sound or deleted the sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 28, 2011 | Logitech X-530 5.1 Speakers
I turned on my xbox360, the speakers were working normally, i removed the VGA cable to confirm it was a VGA cable (want to buy an extension lead for it) then reconnected the cable, now neither of the...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 17, 2011 | Logitech X-530 Computer Speakers
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
VOLUME CONTROLS ARE NOT WORKING.
does your laptop have its own volume control turned down or muted, This is a common error, Post back if no help please.
Jan 04, 2010 | Logitech X-530 Computer Speakers
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Volume control on the master speaker
If its a rotory type control simply take the rest out or off the pcb if you can and on the side of almost any varable resistor or pot is a value. Look to see if radio shack has that value or check your local electronic parts supply house and solder back into place But you may not get the exact one as they all have differant mechanical standards as the shaft may be too long or it may not fit on the pcb so you will have to drill into the cabinet and mount where theres nothing in the way and hook the wires to the control from where the old control was. Hope this helps good luck
Mar 11, 2006 | Logitech X-530 5.1 Channel Speaker System...
Logitech X-530 Computer Speakers Logo
137 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
