Question about Lasko 2535 Stand (Pedestal) Fan
Lasko 2535 Fan will not operate.Just makes a beeping noise when we try to use it.
  • Ed Alvi Aug 27, 2008
    Yea! Oscillating Motor is gone..any one knows as to where to buy one. Lasko does not offer replacement motor?
    Need Oscillating Motor for Lasko 2535.
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Posted on Jul 02, 2010
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
How to grease or oil a lasko fan model u15700
when a fan makes noise while turning,means the bearing is,
starting worn out.best to replace it.when its not turning,its allreddy,
overheated.
Jun 05, 2014 | Lasko Max Performance Pivoting Utility Fan...
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
I do not have a tool to open fan so i can clean the dust out
Hi, a can of compressed air is what you need, can pick them up at most hardware shops, can be purchased online also-http://www.ebay.co.uk/itm/2-x-Compressed-Air-Duster-Spray-Can-200ml-Cleans-Protects-Laptops-Keyboards-/370750150980?pt=UK_Computing_Sound_Vision_Cleaning_Equipment_Kits&hash=item56526e5944
A few blasts should loosen any debris, then simply run the fan to remove any remaining dust.
Apr 12, 2013 | Lasko 2535 Stand (Pedestal) Fan
The fan makes an odd noise as if it were out of
Recalled: Discontinue use and see
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
May 09, 2010 | Lasko 5362 Heater
Lasko ionizer 48" fan
Hi suedevito,
In case an electrical appliance does not do anything anymore, I always first check the fuse(s). There can be a fuse in the electrical plug (in case of UK-type of plug for example) and possibly also somewhere within the fan's housing. In case you do not know how to measure a fuse, just simply replace all the fuses in one go with a new fuse of the same (!) rating. I hope this will solve your problem.
Nov 08, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
LASKO WINDTOWER
is there some kind of timer going off? or does it have s sensor that can tell if something is too close to it? just some things to check.
Nov 04, 2007 | Lasko 2530 Elite WindTower Fan
Lasko 2535 Stand (Pedestal) Fan Logo
848 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
