Question about AEG 23 in. Competence 34602G Gas Cooktop
Lighter unable to light my cooker as if power is out but it is not. Please help
  • Oscarfranki May 15, 2008
    I can get my burner burning but it will not stay alight, only one plate out of five stays alight, i have cleaned the ignitor and stove top and had it serviced, but still the problem persists.
    Champion:
  • 207 Answers
Dirt. Spilled oil, grease, milk etc. act as isolators and prevent contact between burner and casing (mass). You need to take of burners, scrub them, clean them. Don't forget to also clean their seats (brass elements on which they are mounted on).
Posted on Apr 09, 2008
Connect gas cooker
You may have to seek a gas fitter who knows how to make the connection.
Dec 10, 2013 | Electrolux Cooktops
Induction cooker working is ok but immediatly cooker off
CHECK POWER CORD,PANELBOARD JACK OR CONECTOR ,FUSE DRY SOLDERING. FAN CONNECTION.OR FAN (COCKROACHES MIGHT HAVE ENTERED IN FAN). OR THERMISTER BOTH ON COIL AND ON MOSPHET.
Aug 29, 2013 | Cooktops
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Electrolux EOB976: cooker hose or copper pipe?
The regulations state that the proximity of the hob to the cooker would dictate the use of a copper pipe to supply the hob.
Hope this helps.
May 26, 2010 | Cooktops
Cooker igniters are sparking constantly
Please disengage circuit box.
There is probably a short,which would require a licensed repairman. The expense should be minimal, especially next to the high price of a housefire.
Mar 04, 2010 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Nov 21, 2008 | Cooktops
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 | Cooktops
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
AEG 23 in. Competence 34602G Gas Cooktop Logo
96 people viewed this question
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
