Question about Dryers
Removing front panel on electric dryer model number 110.66732500
I have a front loading electric dryer that i need to remove the front panel on to replace the fuse, thermostat and heating element on. I can't figure out how to remove the screws at the bottom of the front panel to gain access to the parts locations. can you tell me how to accomplish this? thankyou
  • 42 Answers
What kind of ***** are they and how big are they.
Are the *****'s start shape, minus shape or some other type.
I also need to know who big are the *****'s. Is the *****s are huge then you will need some sort of drill power tool to open it. And if the *****s are small then it will be easy to use a hand ***** tool.
And always remember keep they electric cord open. Since you are working inside the dryer, *** knows anything might go worng.
Please send me back with full details of your ***** and the model number of your Dryer, Then i am able to help you with my best, Thank You.
Posted on Mar 09, 2008
    Genius:
  • 3,587 Answers
Sure..you'll need to unplug the machine, tip it back a bit, and access those screws from underneath. Do NOT lay this unit on it's back. 45 degrees at most.
and by the way, put something underneath it while working on it.
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    thanks for using fixya...
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Oct 13, 2013 | Maytag Neptune MDG9700A Gas Dryer
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
How do you remove front panel of a dryer?
When you open the door you will see two philps head screws on each side. Two of the screws hold the door on. Remove the 4 screws and the front comes off.
Feb 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Mar 09, 2008 | Dryers
Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Jan 30, 2008 | Maytag MDE9316 Dryer
Front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Dryer
There should be a removable kickplate found at the bottom of the dryer. Remove this kickplate by removing the two screws found at the bottom. Let the kickplate drop down just a little to disengage the two pins found on its top.
If your dryer has an enamelled top, you can raise it by releasing the two spring catches found under it. Use a putty knife (or some other thin and flat object) to push in on and disengage each catch.
Remove the two screws (some models will have four) that secure the bottom of the front panel. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
If your dryer has a galvanized top, remove the screws from the front panel, and then remove the front panel itself. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Thats all you should gain access to the heating coil..
Nov 05, 2007 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
