Question about Dishwashers
Chunks of Junk on my Dishes
I moved into a rental home, and I would swear the dishes get DIRTIER in the dishwasher.......not cleaner. It seems to run thru the cycles just fine, but the dishes are left with chunks of junk on them. HELP!
  • JDBattaglia Mar 10, 2008
    Thank you so much. I will try this.
    Genius:
  • 1,554 Answers
It is likely the drain into the side of the disposer has become clogged . you have to disconnect the rubber hose and run a twisted wire up into the hose and be certain the hole into the disposer is clear, seal the hose back with some silicone as it is old and cracked likely or just watch for any hose leaks .
after that the drain should **** all debris clear.
if not do it again but use a water hose to back flush the drain.
and a bit of bleach in all your washings to break up the mold inside the pipes and keep the dishes clean.
Posted on Mar 10, 2008
  • Karl Whisenand
    Karl Whisenand Mar 10, 2008
    for some reason I got stars in a bunch of my post when using netscape. makes it hard to read.
    I don't even remember what word I used where the stars are.
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Indesit IDL 850 dishwasher: dishes in the top drawer ONLY are dirty: residues is left on and inside what is in the top drawer, so that they come out dirtier than when they went in. This is new: I have not...
If he Dishes Are Not Clean:
- Have you put the right amount of detergent into the dispenser?
- Is the wash cycle suitable for the dishes you have placed inside the
appliance?
- Are the filter and microfilter clean?
- Can the sprayer arms turn freely?
This is how the manual helps.
Jun 29, 2017 | Indesit Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
I'm using a GSD 1100G00WW that is probably from may of 1991, landlord says its fine but, I have had yuckie dishes for two months, how long do these last in hard water? My dishes seem to come out dirtier...
Sorry but FIXYA does not get into wars between tenants and landlords . you have an option to MOVE,or possibly sharing in the cost of replacement unit .
Oct 20, 2017 | GE Dishwashers
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Dishes aren't clean...still chunks as well as a white residue
try cleaning the food trap/sump out the pump may be back washing food if this is partially plugged
Oct 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Dishes not clean
So I have a quite simple fix here for you and you will be happy that it won't cost you anymore money. On my profile I have a tip that includes this. What you will want to do is throw about a cup of white vinegar in the cavity and put it on a heavy wash. What the vinegar is going to do is clean out all the hard water deposits and anything else that may be stuck in there. You dishes will start coming out cleaner again. You can do this every few months or so and it will prevent this from happening. When I worked for Sears as a repair man I would always tell my customers this whether I was there to fix the dishwasher or not as it saved me a service call later. You can also do it in your washing machine.
Another thing you need to make sure you are doing is pre-heating your water before running the dishwasher. Just turn on your tap water and let it run till it is steaming then start the dishwasher. This could be contributing to the dirty dishes too. If you don't preheat the water first it takes the dishwashers heating element a long time to heat that water up. The result is washing your dishes with cold water for the first half of the wash. Let me know if you have any other questions and if this was helpful. This should work just fine for you, good luck and take care.
Jan 26, 2009 | Maytag Dishwashers
Dishes dirtier after washing
start machine, do you hear water running in?? place 4 cups upright on all four corners of top rack, let it run for a few minutes ,open door are the cusp full?? or atleast filling???. if not you have a water issue
Feb 20, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
