Installed spysweeper and i keep getting blue screen ,uninstalled it and works ok again,is there a fix for this?..........error message reads OS Version: 6.0.6000.2.0.0.256.1 Locale ID: 2057 Additional information about the problem: BCCode: 1000008e BCP1: C0000005 BCP2: 818462F9 BCP3: 9B348CF0 BCP4: 00000000 OS Version: 6_0_6000 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\Mini030808-02.dmp C:\Users\Paul\AppData\Local\Temp\WER-84050-0.sysdata.xml C:\Users\Paul\AppData\Local\Temp\WER6850.tmp.version.txt
  • donna mcgill May 11, 2010
    what operating system are you working on? if vista, you will need to visit spysweeper's webstite to download the additional info you will need..
    be sure you do not have another spyware program running in the background.. this seems to be a problem others have experienced.. you can double check this by going to your control panel and looking at all the programs you have installed..
    you may need to clean your drive which can take a several minutes if you have not maintained your pc.. a lot of programs get saved in the background and it's good to have the pc set on an auto mode to clean your drives for you.. it's located under control panel, system tools..
    it could be a memory issue if your pc is old, or that you have spyware or a virus already which probably isn't the case..
    let me know if any of this helps.. d
    Scholar:
  • 121 Answers
You can use the other programs and they are free to download.. here is the site: http://www.download.com/
i would try to install one of these programs, then run a full sweep to see if any of the spyware that is already on your pc will be removed.. this could be why you are having problems installing spysweeper.. i figured since you probably paid for it you would like to use it versus the free downloads.. adaware is my suggestion between the two.. once you sweep your pc, shut it down and start it up again.. then retry spysweeper.. hope this helps..
Posted on Mar 14, 2008
  • 807 Answers
Use Spybot search and destroy and AdAware instead.
Posted on Mar 09, 2008
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
I have a dell xps m140, when I turn on the computer I get a blue screen with the message, STOP: c000021a {FATAL SYSTEM ERROR} the windows logon process system process terminated unexpectedy without...
Hi
You do not say which operating system you are using.
A blue screen can have many causes, so you need to undertake an elimination process to identify the cause.
Most importantly, do not repeatedly keep trying to boot if blue screen keeps appearing, as this could lead to hasrdware failure. It is important to identify and fix the fault as soon as possible.
If you read the full error message, there will usually be an indication of the likely cause of the crash as well as some suggested remedies.
Typical causes are:
Conflict with newly installed software
Driver conflict or corruption
Malware infection
Insufficient Hard Drive space
Operating system corruption
Hard Drive fault
Overheating
Memory corruption
Graphics card fault
Each of these will have a different remedy.
Start by studying the error message in more detail, try the suggested remedy options, then post again with more specific information, if necessary.
Hope this helps.
Aug 22, 2011 | Dell Inspiron XPS M140 Notebook
I want to uninstall spy sweeper but I can't. I get a runtime error. How can I uninstall?
Hi Friend,
Close the SpySweeper Program
  • If SpySweeper isn't closed properly, it may not uninstall completely. Click the SpySweeper icon on the Windows toolbar, then choose the "Exit" command to close it. Hold down the "Control," "Alt" and "Delete" keys at the same time to open the Task Manager. Select "Processes" and look for a process called "spysweeper.exe." If you find it, choose it and then click "End Process." Next, look for a process called "WRSSSDK.exe" and follow the same procedure to close it if you find it.
  • Uninstall SpySweeper
  • Go to the Windows "Start" menu from the toolbar, then choose "Control Panel." Locate the "Add/Remove Program" option and choose it. Once the list of available programs is populated, find and select SpySweeper. Click "Uninstall" and let Windows complete the uninstall process. You will get a message when it is done.
  • Test the Computer
  • Reboot your computer, and once it has restarted, look for the SpySweeper icon on the toolbar. If it is absent, hold down "Control," "Alt" and "Delete" to open the Task Manager. Under "Processes," look for "spysweeper.exe" and "WRSSSDK.exe." If the uninstall was successful, you will not find them. If they are running, end them and go through the uninstall process again
  • Mar 19, 2010 | Webroot Spy Sweeper (spysweeper) for PC
    STOP: 0x00000034 blue screen error... says to disable bios memory options such as caching or shadowing but I can't access windows it keeps restarting and going back to blue screen..... safe mode dont work,...
    This is a cache manager error or a missing DLL file error. This might have heppend as a result of some hardware of software changes that you might have made recently. You can either install the removed drivers once again or need to run a repair reinstall of windows to get the curropt dll files working again.
    http://www.jj54.com/Fix-Error-Number/0x0000/
    Please let me know if this does not help else please accept it.
    Thank You for contacting Fixya.com
    Mar 19, 2010 | Microsoft Windows XP Professional With...
    Virus haveaffected my computer
    In blue screen it wrote some error message read it,if is umountable disk load check all the cables or unplug and plugin them again properly.if any other error message is present kindly re-install the system and install an antivirus software 1st before using any external device or internet.keep the antivirus software upto date.
    Aug 15, 2008 | HP Computers & Internet
    Webroot spysweeper won't sweep
    Dear Sir/madam,
    Reinstall it with different drive before u delete the folder of spysweeper. If you have using pirated version mean it will become problem. so get some other programs of full version. ok
    thanks
    good luck
    Aug 07, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Spy Sweeper won't sweep
    I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
    Jun 04, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Blue Screen of Death!... Video Controller ATI MOBILITY RADEON 9200
    Try uninstalling it and down stepping one rank lower to the moblity radeon 8500 it sounds like you have files that are missing
    and let me know what happens ? ok lala linda
    Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
    Driver blockt work due to compatibility issues.
    A user can uninstall the Windows Vista update that is causing this issue. Once the update is uninstalled you will need to wait until Microsoft has released a fix for this issue. Otherwise, a Windows Vista update may cause this problem to occur again if Microsoft has not pushed a fix yet.
    To uninstall the conflicting update, do the following:
    1. Click Start
    2. Click Control Panel
    3. Click Programs and Features
    4. Choose View installed updates
    5. Select "Update for Microsoft Windows (KB943302)
    6. Click Uninstall
    7. Restart your computer and the update should be uninstalled
    Jan 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Spy sweeper
    What you need to do is
    1.) click start / all programs / axcessories / system tools / system restore
    2.) now restore your computer to a previous date ( one before u upgraded )
    if that dont work you will need to uninstall and re install the program
    cheers
    Jan 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Computers & Internet Logo
    55 people viewed this question
    Alun Cox
    David Payne
    David Payne
