Question about LG CU400 Cellular Phone
Locked on vibrate
Cannot get phone into ring mode, says it is set but it does not change.
  • skywarn132 Mar 09, 2008
    Followed instructions to a tea!!
Problrm solved, found the ringer volume was set to lowest level, thus turnning on the vibrate. Wife did it!!
Posted on Mar 10, 2008
How do I change ringer to vibrate?
U will have Quick setting button on top of notification panel. In that u will be having sound symbol. Click on that to change the volume modes to Ring or Vibrate or Mute.
or
Go to settings option, in that u will have Sound option. Open that. In that u can check the option Vibrate when ringing option.
May 31, 2015 | Samsung Galaxy S 4G Cell Phone
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
LG CU400 Cellular Phone Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
