Question about Bosch SHU9950 Dishwasher
Bosch SHU9915 Does Not Drain
Hi my Bosch dishwasher isn't draining anymore. I ran a couple of rinse and hold cycles to see what it does, and after rinsing with good pressure, it pauses and then signals end of cycle without draining. It leaves water almost over the door seal level. I think the level sensor works because it doesn't add more water if you cycle it again. If you bail out the water and run it, it will does refill. Looked at the little blue impeller under the cover in the bottom and it turns freely. Any ideas, sticky valve, faulty controls? Thanks in advance.
  • 4 more comments
  • Fritz27 Mar 09, 2008
    How do I run a test program to check the module? Where can I find a troubleshooting chart for this model? Specifically, mine is a SHU9915UC/U12. I want to be sure since the board is expensive. Thanks.
    ** warranty, all on my dime. Looks like a module is $115.
    Looking for a Bosch dishwasher repair professional.
  • Fritz27 Apr 25, 2008
    Just wanted to close the loop and let you know what the real problem was... I called my local appliance parts dealer, KenWhirl in Dearborn, MI and the immediately said, well you know Bosch has a seperate drain pump, sounds like you need a new one. They had it in a couple of days and that was indeed the issue. Courious I couldn't find good advice here.
  • haeberle Mar 16, 2009
    Machine
    fills and runs with short breaks that resemble those switching program
    cycles. Water heats normally. HOWEVER, NO WATER IS PUMPED OUT AND
    MACHINE REMAINS FULL AT END OF WASH. please advise,
    Repair clinic answered:"Check the
    drain valve for restriction in the pump and check the drain line to see
    if it is plugged. Note: If a new garbage disposer was installed, remove
    the knock out plug for the dishwasher drain."
    SHU...does not seem to have a drain pump (at least Repair Clinic has no replacement part) - is there a diverter valve for draining instead? Did Fritz27 actually see such a pump. I looked underneath and did not see anything resembling a pump.
  • Steve Papp Mar 10, 2013
    Before you raplace the pump, make sure you have power there, when it sould drain, if not, you have a faulty circuit board
    Brigadier General:
  • 6,966 Answers
If I may add and with the indulgence of IB4G2008 and Jaime867.....
Have you physically checked the drain, drain filter and drain hose for any blockage, clog, kinks and/or anything out of the ordinary pls?
You can also try running a slightly above pressure hose backwards from the drain and try to see what comes out in the drum.
Good luck and kind regards.
Posted on Mar 10, 2008
  • 2,326 Answers
Go to the following link to get more info about your dishwasher issue.
    Genius:
  • 3,587 Answers
Faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Posted on Mar 09, 2008
  • 4 more comments
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    of course, could also be the relays..but since most of these are integrated circuits, you wind up changing the board anyhow.
  • Patrick Michaels
    check this link with the precise model number for parts assistance.
  • Patrick Michaels
    unfortunately it's more of a workbench issue. swap outs these days, instead of component level troubleshooting...this still under warranty?
  • Patrick Michaels
    well..then that's how it's gonna go..the change isn't that tough, actually...a little patience will do it..
  • Patrick Michaels
    so, after all this, you considered my assistance to be not worth it. that's really and truly sad.
  • Patrick Michaels
    here's a tune that this reminds me of..
I have a Bosch SHE55C05UC dishwasher and it just started to not wash properly and leave water in the pan below (first time it did not drain at all.. I tried the rinse/hold cycle and got the unit to drain...
I am assuming you have checked the filter and drain sump and there are no obstructions. Have you tried taking the drain pipe out of the sink downpipe and checking if it drains directly into the sink?
I am also assuming the wash cycle is completed when you open the dishwasher.
Do you hear the drain pump running?
Post your comment after you have checked the things I mentioned.
Jun 17, 2010 | Bosch SHE55C05UC Dishwasher
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Our dishwasher does not progress beyond the wach cycle to the rinse cycle. It will run for hours and still has soap in it.
I'm positive of this, but your dishwasher may qualify for a somewhat recent recall. Call bosch to see. If you can get it to drain manually and put into rinse and hold manually, but it won't progress on it's own, then it's the control board. Hope this helps.
Nov 28, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Bosch SHU9950 Dishwasher Logo
799 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
