I too have lost the manual to my 43-3829 answer machine. I read your solution to recording a message, which was enormously helpful. Now, can anyone help me set the sassafrassin' time and date?!? Thank you.
Hi, here are the instructions for setting the time on a 43-3825, which is a very similar model. They should work for your machine too.
1. Press and hold TIME SET/CHECK/>> until you hear it beep twice.
2. Press ANNC/DAY/<< and the machine will say a day. Keep pressing that button until you hear the correct day.
3. Press REC and the machine will say the hour. Keep pressing it until you hear the right hour.
4. Press >= (the play/pause button) until you hear the right minute.
5. Once you've gotten the correct day and time, press TIME SET/CHECK/>> to save it.
While you're doing this, you can't let the machine sit idle for more than 5 seconds at a time, otherwise it will exit the time setup and you'll have to start over again. Good luck!
