Question about Dryers
LG Dryer problem
Hi there. I have an LG dryer, TDC70040E. Instead of heating the cooling light stays on so only cool air is blown. I talked to the service center and they said that as the cooling light was on it did not necessarily mean that the heater had stopped working, it may just mean the sensors need cleaning. I cleaned them all and the colling light remains on.
Any ideas?
  • 2 more comments
  • sigmatroy11 Dec 30, 2008
    i have the lg dlg 2525s when running the cooling light stays on. i
    I cleaned the sensors and the light is still on.
  • pcmechanic3 Feb 04, 2009
    same problem cooling light stays on takes a long time to dry clothes how do you clean sensors please help thanks
  • ayanalise Feb 24, 2009
    LG DLE5977W... cooling light is on as well as check filter light.... tried turning everything off and unplugging all the circuit plugs behind face. That didn't help. Dryer's been nothing but problems!!!
  • Anonymous Mar 02, 2009
    cooling light wont turn off
I had/have the same problem at the end of the manufacturer's 2-year warranty and had it repaired. Whilst diagnosing the problem the engineer came across a number of symptoms - wouldntt heat up, "ELE" error and beeping, the thermal switch behind the back cover had cut-out - resetting it the dryer only worked for 15mins. it then wouldn't switch off! (kept turning) and the only way to switch if off was to pull the plug at the mains. Had the control board and motor capacitor replaced - it worked for one year and the same problem again (right now). it is one year into extended warranty and beyond economical repair, £250 to replace control board, and I am being offered £165. Comparing the old and new control boards I note that the same power transistor has frazzeled on both boards. I can replace the tarnsistor and other frazzeled components but the thing is covered in resin - i'm peeling off as I write this!. Not buying LG again. But impressive flashing lights when you switch it on though - just telling her to buy a flashy christmas tree instead!
PS this is the short version of events.
Posted on Sep 02, 2008
My lg dryer dle3777 electric is not drying. The cooling cycle light is blinking and the air never heats up.
Check the heating element, Hi limit or any thermisters(Especially on the exhaust). The heating element should read about 40 ohms.
http://www.repairclinic.com/PartDetail/Heating-Element-Assembly/1268157
See if this helps.
Feb 22, 2011 | LG DLE3777 Electric Dryer
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Not drying completely
try cleaning real good. also the heating unit might be bad
Aug 05, 2009 | LG DLE2514 Electric Dryer
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
Cooling light on?
The cooling light is always on, it flashes when it is in that part of the cycle, sounds like he put it in to a test mode. Was it a thermistor that he changed?
No heat, sounds to me like a thermostat might be blown. Call the guy back, if you haven't already.
Sgt 48
Apr 05, 2008 | LG DLE5977 Electric Dryer
LG DLG5988W Gas Dryer (NO HEAT)
I'm pretty sure that the cooling light is always on and blinks when it is cooling. I look at my brother's and he has the EQ bar and it acts the same.
Dec 04, 2007 | LG DLG5988 Gas Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
504 people viewed this question
Top Dryers Experts
Marvin
Marvin
