Attention **ggin, your ranking Guru: I have 3 problems: First, I can't remember what to do to change or check the ink cartridges in the printer (Epson Stylus CX6600.) I have misplaced or lost my manual. Can you please send me a**ther one for this printer? Second, my actual problem right **w is that I have plenty of ink available in all cartridges, but my black ink is **t printing right **w. There could be a**ther one **t printing also, but I frankly don't k**w which one that would be. I suspect the green (combination of blue and yellow, I k**w, but I seem to have plenty of yellow printing.) ** blue and ** green, so I guess it's the blue. I thought I'd shake all cartridges real well, once you tell me how to get to them. Should I be cleaning something? Whatever that is, I'll need to k**w what and where it's located, then how to do it. Third. Each time I start to use the printer after being away from it for awhile (a few hours), it will say on the screen that the printer is **t ready. I will have to turn it off, then turn it back on. Once I do that, it will start printing. I've ***** had that happen before. What do I have to do to fix it? Be aware that I'm a woman who has ** idea how to fix anything. I will have to be led through very well - ** steps left out or I won't be able to follow. My husband is blind and is of ** help. Okay? Thanks for your help. Kathye Long
  • 26 Answers
On the front of your printer there is a window with butons around it that alows youto select ink levels
Posted on Mar 10, 2008
How to hard reset HP 900 Inkjet Printer?
Hard reset refers to powering off. Like unplugging the cord.
Jan 02, 2013 | Computers & Internet
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Message appears-Ink Absorber is nearly full
Found solution posted on Aug 05 2008 by worldvet (rank:Guru)
Thanks for help
Robert Harwood
Mar 25, 2009 | Canon PIXMA iP2000 InkJet Printer
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Changed the black ink and while it's seems like the document is printing, no ink appears on paper.
This was Rob's response to a similar problem which I had. d0c4ec0.jpg robmcd27
Rank:guru_s.gif Guru
Rating: 85%, 6 votes
The black ink is not the problem, it's the nozzle. The nozzle for the black ink head is clogged with dried up ink. If it were mine, I would remove the print head and use a q-tip dipped in alcholol to clean the nozzle. Let the alcohol dry and put it back together and run another auto print head cleaning.
You're probably going to have to do it a few times. It's going to depend on how bad the clog is. This will fix you...just be patient. Remember that ink has been dried on several months. Don't forget to rate my help. Thanks for coming to FixYa.com
Rob
Dec 21, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
How to change the ink cartridge?
1: Turn printer on
2: Lift up front panal (below scanner)
3: Wait for print head to appear
4: Remove old cartridge (push down & towards you)
5: Push new cartridge into position
6: Close panal & wait for the Printer to prime the cartridge.
If you are using a PC with check it works in the printer section of Control Panal
Mar 31, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
