Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Oven light won't turn off
The oven light on my Jenn-Air SVE47100b slide-in range is on and will not turn off. We have checked the door, and it is closing properly. The light will not go off even when we push the button inside the door by hand. We have tried unplugging it, and the light comes on as soon as we plug it back it. Any suggestions?
  • 3 more comments
  • Natalie_Bray Mar 16, 2008
    Thanks for your suggestions -- we just tried replacing the switch on the outside of the oven that controls the light, and that didn't work. Next we will try to replace the switch button inside the oven. In the event that doesn't work - how can we tell if the relay is stuck closed, and if it is, how do we fix it?
  • qgneedshelp Jan 03, 2009
    we have the same problem. No matter what we seem to try, nothing will turn off the light. did you ever find the solution?
  • dorisanne Apr 09, 2009
    We have a Jenn-Air dual-fuel downdraft slide-in range. The oven light will not turn off. If we find that the relay is at fault, how do we repair it...hopefully without a service call?
  • Anonymous May 02, 2009
    Our light will not turn off either. Everything else appears to be working, the door shuts properly, etc.
  • Anonymous Mar 26, 2014
    The oven light won't go off if the oven is plugged in. The button that is pushed when the door closes seems to have tension but does not turn off the light.
  • 142 Answers
It sounds to me like the switch that operates the light is malfunctioning. You're taking the right steps by pressing the switch by hand. Since that didn't work, either that switch is not working or there is another switch that is intended to keep the light on while the door is closed. You can look at that one too. The last thing to consider is if the light is relay controlled, the relay might be stuck closed and applying power to the light all the time.
Posted on Mar 09, 2008
Jenn air oven won't open after cleaning. What can
on some models if you unplug it for a few minutes
it will unlock itself when you plug it back in
Oct 09, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My wife cleaned our oven yesterday. Now we cannot open it. The lever appears locked and I see no easy to grasp instructions. It is an older model and we are renting this home. Any help would be...
Sounds like the oven is still hot in side. have you tried to hold down the stop/cancle button for 10 sec. to unlock it. also here is the manual. look in page 26 for some tips on how to unlock.
Good Luck
Jan 20, 2009 | Jenn-Air SVE47100 Slide-In Electric...
It was recommended to me by your service that I call a service person. I did that. thanks.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air sve47600b oven door hinge
good old 3 in 1 oil or olive oil if none, if problem still there could be wear on hinge
Sep 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
3,370 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
