Question about Saeco Magic De Luxe Espresso Machine
Water light is flashing but tank is full
Hi Pierre,
The water level light is flashing, but the tank is full. I checked the magnet, and it moved appropriately... Any ideas?
  • 1 more comment
  • Bree61o Mar 09, 2008
    Sorry, I forgot to say that this is a Saeco Magic De Luxe Espresso machine.
  • mh123 Mar 13, 2008
    Yes I do have the same problem what I should do.
  • Jakopath Mar 29, 2008
    I read the previous post, but I am still unclear how to reprime the water system. Also, trying to figure out where exactly the filter is.
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Posted on Mar 20, 2008
Very late response, but i just had the same problem and hope this posts helps someone. you have to drain the machine. place a cup under the steam wand and open up the knob until the water runs steady.
Posted on Dec 17, 2010
  • UrsulaR Dec 17, 2010
    oops, didn't read all the responses before posting. sorry!
Great fix, thanks, now how do you get a new filter for this machine, Saeco doesn't list it on their web site anymore. Ekohler
Posted on Mar 22, 2008
Can you explain the step to get the water sensor stop flashing
Posted on Mar 13, 2008
  • 2,039 Answers
If our water stay on it the sensor inside you have to open it up uin the back white sensor with 2 wire
Posted on Mar 10, 2008
Why does my em69 coffee machine red light stay on?
There is most likely a problem with the magnet in the water tank and the machine thinks it is empty. New magnets are available in eBay for around $10.
Jul 08, 2014 | Sunbeam Cafe EM6910
Tip
Krups espresso machine keep asking me fill up the water tank even it is already...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons.
First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it cannot be fixed then you need a new float.
If you want to fix it temporary until you find a new float you can use a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
on Aug 16, 2010 | Coffee Makers & Espresso Machines
Low water warning light flashing when water level is not low
The water level sensor is based on a floating magnet. The magnet breaks out of it's holder in the water tank. Remove the water tank via the door on the back of the machine, tip the water out (and the magnet will probably come out too). Put the magnet back in the housing down near the water valve, and wedge the black lid on with a bit of plastic. Refill and enjoy coffee.
... or put some black tape over the red light.
Feb 13, 2014 | Sunbeam Coffee Makers & Espresso Machines
Saeco Odea Giro : Water tank problem
The only thing I can think of is the reed switch on the back of the panel that checks the water level. If there is a float in the water tank check what level it is when it calls for refill, it might be in backwards, or the magnet has moved.
Mar 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
Oct 05, 2009 | Philips Senseo HD7832 Coffee Maker
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water...
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Nov 17, 2008 | Krups Small Appliances Espresso Machine
Reservoir empty tank lights up but tank is half full of water
in the water tank you have a little magnet that magnet need to move up and down shake the water container to see that magnet move .thanks for using fixya
pierre
Feb 26, 2008 | Saeco Magic De Luxe Espresso Machine
The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
605 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
