Question about Pioneer VSX-D458 Receiver
6.3a slow-blow 125v fuse
I I went to Radio Shack to buy my open 6.3 slow-blow 125v fuse and they didn't have it. But they did have a 6.3 slow-blow 250v fuse. Will this fuse work or do I have to look for the 125v fuse?
blew 125v 6.3a fuse in my pioneer digital processor cant find a replacement
    Scholar:
  • 154 Answers
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Posted on Oct 12, 2017
SOURCE: pioneer vsx-07tx-blows fuses immediately
put 20a fuse in.
Posted on Dec 29, 2007
  • 4234 Answers
SOURCE: Home Amp fuse keeps blowing
This usually happens when there is a problem with the main power supply and is relatively rare. If you can post the make and model, I can give you some things to check if you are somewhat familiar with electronics.
Thanks,
Dan
Posted on Feb 19, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
Posted on Apr 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: MY PIONEER VSX-D498 DIGITAL SIGNAL PROCESSOR
As with anything, diagnosis comes before repair. It needs a hands-on pro to look at it.
Posted on Feb 03, 2010
Grubhead
  • 5515 Answers
SOURCE: I had a bad speaker wire on my Pioneer vsx-305 and
You can get fuses from any electronic parts shop, such as Maplin (UK) or Radio Shack (USA). I would get a few, because chances are the fuse did not just blow because of a bad speaker wire! Fuses are there to protect the device from an overload (which would cause a fire). The mostly likely cause of your fuse blowing is that your wire shorted out an output transistor on the channel the speaker was connected to and the transistor is acting like a piece of wire now!
If you have an Ohm meter I would put it's probes on the terminals of the transistors on the heat sink. You will soon know, as it will be just like you have touched the meter's probes together!
Posted on Apr 26, 2010
I just got a free sharp LCD LC19SB27UT and it has a power problem, I opened it up and notice a fuse was dead, this all happened because a friend was using it in a thunder storm, I went to radio shack and...
on the power board you will see a black flat ac converter with this on it + ~ ~ - on it check this with a meter its more than likely to have gone as its the first thing to go in a storm. the + and - can be the other way round ~ ~ is the mains volts in and + - is the volts out if the ~ ~ has no resistance it has blown and it will keep blowing the fuse check the + - and you should have a resistance from the rest of the power board.
Jun 05, 2017 | Sharp LC19SB27UT LCD TV
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Apr 28, 2010 | Panasonic CT-36SX12 36" TV
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Pioneer VSX-D458 Receiver Logo
107 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
