Yellow vertical line
Dear Sir,
My problem is showed in the image below
This line comes out when the lcd is powerd on even if **t connected to PC.
the lcd is Lg model name L1760TR,
can this problem be fixed or **t
**te that ** service center for Lg is at my country
thank you very much for your concern
Lightly press on the line at the top and bottom of the screen. If the line goes away while presses then its the TCP connector problem. You will have to open the monitor and use a piece of soft rubber to keep the tcp pressed.
Word of caution: TCP is extremely fragile, so be very careful.
Hope this helps
Posted on Mar 11, 2008
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem.
Apr 08, 2014 | Vizio Televison & Video
Vizio LCD problems: LCD control board or LCD panel?
I think you are looking at a defective LCD panel. But the set will need to be properly diagnosed to tell for sure.
Sep 04, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
2 vertical line in laptop screen coming
Only way you are going to be able to remove this is by replacing the LCD. It is not a huge job, and not extremely expensive if you can do it yourself.
Here is a link to the maint and service guide that should show you removal and replacement of parts.
Mar 17, 2009 | Compaq Presario M2000 Notebook
most of lines vertical or horizontal are defects in the screen that can't be repair unless you change the lcd screen, which is very expensive, in my experience this lines wont disaperar by any mean that I know, this monitors (all lcd) have a very delicated circuitry that can fail in a joint between the lcd panel and the circuit board (solid board conected by a flexible circuit ribbon to the lcd) unless you have warranty, I think you will got to live with this defect, or change that monitor. hope it help.
note: some hot air in the joints will help but if you dont got experience on this tool could be worst (not recomended).
Jul 29, 2008 | Computers & Internet
LG L1760TR Problem
This is a problem of the panel and generally not fixable.Contact LG service center ,Normally a 3 year warranty is provided.
Mar 10, 2008 | LG Flatron L1750S 17" LCD Monitor
Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
Computers & Internet Logo
974 people viewed this question
David Payne
David Payne
