Question about Indesit 24 in. D61 Free-standing Dishwasher
Tripping power Hi , Please help my indesit dc6100 w is tripping the power when the dial reaches ** 2 cycle.What component will be faulty.
    Novelist:
  • 142 Answers
Don't know what the 2-cycle is... but here are a couple things to consider:
Dishwashers by code must be connected to a GFCI circuit since they handle water. If there is a faulty ground anywhere on the device the GFCI will trip, hence saving you from being electrocuted. If the circuit breaker is under rated and the 2-cycle is drawing more current than the rating, it will blow. The dishwasher should be on its own circuit also. If more than one appliance is on the same circuit, it may be too much for that circuit. My guess is that the 2-cycle is trying to heat the water inside the washer and drawing alot of power. Make sure the rating of the circuit breaker matches the manufacturers recommendation.
Posted on Mar 10, 2008
  • Frunk Nov 30, 2010
    Mine done the same then eventually tripped every time i put a cycle on.I unplugged it. I then disconnected the two connecters that go onto the element leaving the earth on. I put the plug back in and put on a cycle,it worked fine(but cold) this told me it was a problem with the element. I replaced the element which was around £35 and now it works like new.It was'nt that easy though as access to the underside of the dishwasher from the back is restricted. All in all it probably took a couple of hours and im not normally that handy with tools but the idea of doing the dishes again was enough motivation for me to get my hands dirty.But i would stress that you unplug and disconnect it when doing any work.
My hoover optima washing machine is tripping my electricity supply. Have tried disconnecting heating element and looking for damaged wires.
Ian if the circuit breaker is a rcd it will trip off the supply if it
normally detects a very small leakage or unbalance of around 35 m /amps this could be a small water leak onto live parts in the machine or a minute short to earth on one component ,make sure all parts are dry / is it tripping when you switch power on to machine or does it trip when machine is in cycle mode.
1. its as first suggestion 2. it's a component like pump or drive motor that;s causing problem. hope this is of some help,g.luck
Nov 11, 2016 | Hoover Washing Machines
Valentine Pension 1-83. The fryer heats the oil and then the switch on electric board trips? Please help
Hi there!
Check the rating of the electrical circuit breaker where the unit is tapped, it must be at least 25 % higher than the unit' s current rating on nameplate to avoid tripping.
If hi-limit of the unit trips after reaching temperature setting, try lowering the set point; hi-limits are designed to trip off at 450F for safety. Or it may be faulty causing premature or early trip off temperature.
Regards.
Apr 03, 2014 | Imperial IFS40 Deep Fryer
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Hotpoint wm53 unknown problem
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Jun 17, 2009 | Hotpoint Washing Machines
Indesit w113 and w1101 wasing machines dial clicking round
This type of fault is usually associated with a faulty programmer. if you have a reset point, then try to reset it, if no reset, then programmer is faulty.
Please rate my solution.
Thanks.
May 11, 2009 | Washing Machines
Tripping of electrics
Check the heater has not shorted out.....feel the heating element it should be smooth ...... if there's a rough spot it has blown and will have to be replaced.
feel the heater
Dec 16, 2017 | Indesit 24 in. D61 Free-standing...
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Indesit D61D Sticks In Its Cycle
The repair can be done yourself you need to first purchas a can of liquid wrench with extention. and first shut off power or disconnect power. there is a acess panal that you need to remove to get at gears to grease once it is greased you will need to turn the dial a couple of times (powerless) and replace the panel and plug or turn on power (when you are turning the knob besure to return to the start cycle ) if you need more info please email me kcord44@yahoo.com thank you and good luck
May 29, 2008 | Indesit 24 in. D61 Free-standing...
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Indesit 24 in. D61 Free-standing Dishwasher Logo
391 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
