I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration. Readers Respond:
have you ran the installation wizard that came with that router. it will make the connections for you. and you have to have a wireless adapter in your computer and turned on when you do it. the wizard will walk you through it, it is one the installation cd
If you connect the computer directly to the modem, does it work? If that works then the modem is working. Now connect the computer to the router and the modem to the router. You will need to open the set up page of the router to check the settings of the router. You can set up the router without the CD also. It is very easy. Click Here for step by step instructions about how to set up the router
There's a cable that comes from the modem that plugs into the WAN port on the dlink router. Then you connect one of the other ports(1,2,3, or 4) into the network card on your computer. The connection and network cable look like a phone cord/connection just bigger.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
