Question about MSI Wireless-G RG54G3 Router
Msi rg54g3 wireless router
Wi Router will not let either of my cp's to connect to WAN. Am able to successfully ping current cp (hardline from wi router) but am not able to connect to internet. All firewell/antivirus/spyware prog disabled. Internet explorer freezes and makes a clicking sound over and over (page cannot be displayed). On net connections am showing 100mbps. Running gateway and subnet according to wi router specs (default). Not sure of cp IP though.
Win XP plat
Comcast High Speed
Nvidia nforce mcp net adaptor on Nf7s mobo
  • timmyboy61 Mar 10, 2008
    Good news, that did it for my hardwired cp! Thanks. My wired cp will still not connect! I've been over and over it. Still cannot figure this out. Both cp's set to auto find adress. Worked well for hardline and Comcast modem reboot but not other cp. Will find network and connect on manual adress but will not allow gateway access (192.168.1.254) to manf. site. Also does not show up in clients list. Another interesting thing is that both cp's wired or will not accept ping (ping failure).
Cable modem or DSL? If cable modem without phone service, modem power has to be unplugged 2 minutes before the router is connected in order to release the mac address from memory. If cable modem with phone service, same thing applies, but battery backup must also be disconnected.
DSL modem may require PPPoE setup into router.
Posted on Mar 10, 2008
Hi there. I want to configure my MSI RG54G3 for PPPOE. Could you please help?
You have to access the router page first. http://192.168.1.254. Try to use admin as username and admin as password. You can also try to put admin as username and leave blank for the password.
Once on the router's page, you will need to look for the setup wizard. For the connection type, make sure to select PPPoE and match the settings with your current ISP.
Jan 31, 2011 | MSI Wireless-G RG54G3 Router
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
I can't connect to the internet with dlink router
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have connected MSI RG54G3 to a caple and it's not give me ip and internet access
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 01, 2009 | MSI Wireless-G RG54G3 Router
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
How can you set up a network of 4 computers with a RG54G3 router?
*** configurez router ,ca nu am cd la el nici manual rg54g3 msi
Feb 26, 2009 | MSI Wireless-G RG54G3 Router
Wireless conncection
depending on who your ISP is, you need an ethernet cable coming from the modem into the WAN/Internet port on back of router. Once that is in you can try to connect wirelessly using the settings your router is setup for :
SSID/network name
encryption type
encryption key/passkey/passphrase
-- this part is dependent on above setting
wireless channel
Jul 08, 2008 | MSI Wireless-G RG54G3 Router
Help me please
Two separate solutions are needed.
First, you will need to ask your ISP (Internet Service Provider) to assign a "fixed IP address" to your Internet connection. Your ISP typically assigns addresses to home users out of a large "pool" of addresses that are shared among several customers. Because of this, your home network address is not always the same. Most ISP's charge an extra fee to always keep your address the same.
The second task is to configure the firewall function in your router so it will pass connections through from the WAN to the device inside your network. The procedure to do this should be included in the instruction manual for your router.
Jan 06, 2008 | MSI Wireless-G RG54G3 Router
Msi rg54g3
i take it by your comment "unauthorised people been accessing it" that you wish to use the router wirelessly? do you currently have any type of encryption set up on the wireless signal at the moment eg WPA(2)-PSK, WEP, etc?
Sep 17, 2007 | MSI Wireless-G RG54G3 Router
MSI RG54G3 router cannot connect to internet
i hink this issue has been resolved by you by now. if it perists do lemme know about it. it seems yor router is not configured properly regarding the authentication like user name n password. n i think the MAC address spoofing is also into the picture , mostly MAC add spoofing is done on cable connections but sometimes it can be also used with the "user id n password" together. For any other issue- chat with me on msn or yahoo messenger my id is samrat101 on both the messngers samrat
Aug 12, 2006 | MSI Wireless-G RG54G3 Router
MSI Wireless-G RG54G3 Router Logo
195 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
