Bush digital terrestrial receiver dfta 11
I have a bush dfta 11 digi box. the standby light should be "red" for off and "green" for on but for some reason its flashing red. pressing the standby on the remote has ** effect. i have tried the remote on a**ther unit and it work's fine, so the battery's are ok, any ideas you have would be gratefully receaved
John
L have my own problems unable to turn red light on box to green have checked batteries in handset are ok.
Posted on Apr 11, 2013
  • 372 Answers
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Posted on Mar 09, 2008
I need to unlock my bush DFTA 11 recceiver have forgotten code plz help
Posted on Apr 18, 2010
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
May 26, 2009 | Televison & Video
Thompson DTI 6300 16 Red light all the time
hi
The solution has been listed as a Samsung recorder rather than the Thomson listed above
regards
manby
May 18, 2009 | Samsung HDTV Digital Terrestrial Receiver
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
572 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
