Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Will not spin
The washer will not spin or drain. It makes an unfamiliar noise.
  • 2 more comments
  • Anonymous Mar 30, 2008
    top loader washing machine wont spin
  • tired441 Apr 09, 2008
    Washer will not spin with any type of weight in the machine; will work fine with on 2 - 3 towels but not even a small load. I have had a repair man out to the tune of $120.00 and it worked again for about a month. I hate whirlpool!
  • Anonymous Apr 13, 2008
    simpson wahing machine do not spin or agitate one day, after emptying works next day but stops again
  • Ian Greenland May 11, 2010
    make and model
    Sergeant:
  • 351 Answers
Check the drive coupling between the motor and gearcase,but dont lie the machine down to check
Posted on Mar 12, 2008
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Our washer is making a grinding noise when the washer drains and when the tub spins any ideas what it might be. Washer seems to work fine just making that noise during a drain and spin cycle.
This sounds like you may have something caught in the drain pump. One of the most common items to get stuck in there is a woman's bra wire. Check it out.
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
