Question about Kitchen Ranges
Jen-Aire stem problem
What would you suggest using to clean the gunk that may be causing my problem?
    Genius:
  • 3,587 Answers
Well..denatured alcohol usually works. just want to keep the sudsy cleaners out, since they only make it worse. I used that on commercial counter stoves for years..works good..and use those tight swabs like from doctors offices, not the ones for ears..
Posted on Mar 09, 2008
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
I have a jen-aire ww27430w double wall oven. The display is giving me an ''F'' code with no number after it. I have shut the power off overnight and tried to reset to no avail. I disassembled, and...
This is a bad power relay board that you need to replace on this unit. We are Jenn-Air factory authorized service and parts suppliers and have parts available to ship out when you are ready for them. We also provide part removal/installation instructions when we send parts out, should you need this information, also.
You can contact us from 7 AM until 7 PM CST at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
when you need us. We look forward to hearing back from you. Thanks, Ella
Jan 17, 2010 | Kitchen Ranges
Jenn aire model sve47500b has very dim display light. Clock almost unreadable
call jen aire
with any luck its covered under the 5 year electronics
part of the warrenty this was a huge problem with jen aire like 3 years ago
Sep 13, 2009 | Cooktops
2 speed vent fan now only works at high speed
the control board resistor for the fan control has gone this controls the voltage to the fan, it will need replace. with this not working the power goes straight to the motor.
Jun 15, 2017 | Kitchen Ranges
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Steamer backed up water pours out under machine
On the cva 610 and 615 the steamer valve gasket tends to wear. Causing the unit to leak. Your best bet it to remove the steamer valve, Looking at the knob stem there is a plastic pin you can press to remove the stem from the valve. Once removed there's a small o-ring on the stem. ( That's where it's leaking from ) replace the o-ring and the stem to be safe. Also take a look at the micro sw to make sure it doen't have any corrosion if so replace it. If not your on the road to recovery. Good luck
Dec 29, 2008 | Miele CVA610
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
