Question about Panasonic KX-TG5632 Phone
KX-TG5631 handset handset does to work. looks like battery is dead. station works well. where do I get a battery to fit the hand unit locally? west side el paso. My email is noted, rblumen1@elp.rr.com, my name Ronald Blumenfeld, 6103 Pinehurst Dr. El Paso, Tx 79912
  • Anonymous Mar 18, 2008
    not have a tone
  • samalik Apr 02, 2008
    handset does not work.
I can't a make call not dial
Posted on Mar 18, 2008
No display blank screen
hi sir. the problem is the flex wire of the display on the handset unit and this is common. you have 2 solutions. first change for a new the handset unit. or open the handset, remove the main board, separate slowly the display screen from the main unit. whit a hot air gun, give some hot to the white flex on the main board side(not too much or you can destroy that). and tighten a little with your fingers on the flex and the main board. This should paste the flex.
Nov 09, 2013 | Panasonic KX-TG5631 Cordless Phone
ONE OF MY HANDSET FELL INTO THE POOL. DRIED IT OUT AND RECHARGED THE BATTERY, BUT IT SEEMS DEAD. IS THERE A RESET TRICK OR DO I NEED A NEW HANDSET? ARE THEY AVAILABLE? Model # kx-tg2622 in white
No magic will fix this hand set ... best you remove the battery and retire the unit. You can probably get a single replacement unit where phones are sold.
Thanks for your interest in FixYa.com
Aug 26, 2011 | Panasonic KX-TG2622 Phone
Callers cannot hear me with one handset
Try them in intercom mode. If the flaky unit still does not work, the something along the microphone circuitry is likely dead. If its in warranty, get a replacement from the store or manufacturer.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Panasonic KX-TGA400B De-register handset
You do not need to power up the handset to delete the old intercom number, you do this on your base station. At your base push Function, then scroll up to Registration, push Enter, scroll to de-registration, push enter, scroll to the right and highlight that intercom number that you wish to delete, push Enter then Clear. If your not sure which intercom number it was, take a piece of paper and a pen and look at each functional handset you have, and notate the intercom number which is in the upper right hand corner. You can send your dead handset in for repair to have a backup, so don't toss it.
Mar 17, 2008 | Panasonic KX TGA400B Cordless Expansion...
Panasonic KX-TG5632 Phone Logo
394 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
