Even when all of the knobs are turned to off the sparker keeps clicking.
The pilot light and gas work fine
SOURCE: oven igintion "click" starts the oven but then starts reclicking
hello,
this is an indication of weak wires from the connection of power supply over the range.
what you need to do to fix up this problem i to open up the range with the bass tools then trace down the wire to the power panel that distribute power to other part to function smell the wires to detect the born/weak wire from others then you make a replacement of the wire , but if you did not have the technical skill or the knowledge to apply the explanation above then it is advice not to do it your self to avoid more damage on the range.
please before you can carry out this above information you will have to put off all form of power supply connected to the range.
thank you and thanks for using fixya.
