Question about GPS
Navigation fatal error Error 1706
Can't use the navigation on this new gps i just purchased. When pressing navigation button on main menu I get----
Fatal error: initiation error, ** language files found. Then says error 1706-** valid source could be found for product ASUS R300 GPS Catcher -- Windows Installer can**t continue
It also says error 1603- Fatal error during installation. Consult windows Installer Help (Msi.chm or mSDN for more info.
  • Anonymous Mar 31, 2014
    I have GPS portable navigation device model KMG 2907 and it was working perfectly but i had tried to change the sound settings but i got a while screen with only a cross line to align the screen and i can't return back to the main original menu even i had tried to use the reset button but also it is not working , appreciate your advice.
    Genius:
  • 3,587 Answers
Oops..sounds like maybe your drivers are unhappy...
Posted on Mar 09, 2008
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    seems that perhaps the firmware needs a major update based on the blogosphere...
  • Patrick Michaels
    what is model number of one you have?
  • 13,433 Answers
Heres what microsoft says about 1603
http://support.microsoft.com/default.aspx?scid=kb;en-us;834484
CAUSE loadTOCNode(1, 'cause'); You may receive this error message if any one of the following conditions is true: • The folder that you are trying to install the Windows Installer package to is encrypted. • The drive that contains the folder that you are trying to install the Windows Installer package to is accessed as a substitute drive. • The SYSTEM account does not have Full Control permissions on the folder that you are trying to install the Windows Installer package to. You notice the error message because the Windows Installer service uses the SYSTEM account to install software.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, do any one of the following, depending on the cause of the problem: • Install the package to a folder that is not encrypted.
Use this method if you receive the error message because you try to install the Windows Installer package to a folder that is encrypted. • Install the package to a drive that is not accessed as a substitute drive.
Use this method if you receive the error message because the drive that contains the folder that you try to install the Windows Installer package to is accessed as a substitute drive. • Grant Full Control permissions to the SYSTEM account. (for Windows 2000 and Windows XP only)
Use this method if you receive the error message because the SYSTEM account does not have Full Control permissions on the folder that you try to install the Windows Installer package to.
To grant Full Control permissions to the SYSTEM account, follow these steps: 1. On the Windows desktop, double-click My Computer. The My Computer window appears. 2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties. 3. Click the Security tab. 4. On the Security tab, do the following: • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account. • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box: a. Click Add. The Select Users or Groups dialog box appears. b. In the Name field, click SYSTEM, and then click Add. c. Click OK. 5. In the Permissions section, click to select the Full Control check box under Allow, and then click Advanced. 6. Do the following: • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK. • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.Note If you receive a security message, click Yes. 7. Wait for the operating system to apply the permissions that you have selected to all child folders. 8. Run the Windows Installer package.
My Evesham nav-cam 7000 model ps1025 is showing
My Evesham nav-cam 7000 model ps1025 is showing the following:-fatal application error Application Mobile Navigator.exe has performed an illegal operation and will shut down.If the problem persists contact the program vendor.Program 0xc0000005 Address 000d026c.What can i do to remedy and get a cd disc for it?
Oct 12, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Gps freezes , wont load up,and fatal application error comes up
Your getting fatal error's ? Your going to need to have this services if it freezes! There is not a easy fix for this one..
May 24, 2009 | Nextar X3B GPS Navigation System
Displays error 1706 every time i use nmy computer
error_x.jpg What Causes Error 1706 Error 1706 is a critical Windows error and is caused by a corrupt registry entry that should be repaired immediately to prevent further corruption in other applications and/or hardware. Risks include hardware failure, blue screen errors and fatal crashes. I found this on the internet by typeing in Error 1706 at google. If you have Norton Tools you need to runit or some other Registery Repair software.
Mar 06, 2009 | HP Office Equipment & Supplies
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
I have a E4330i GPS which has been working perfectly for the past 3 months. The last time I turned it on however, while loading the GPS software a "Fatal error, restarting" came up on the screen...
Found this here: http://forums.gpsreview.net/discussion/3361/fatal-application-error
Press the reset button on the right side of the device. It will power off the device. Once the device is turned completely off, please press On/Off button for 3 seconds to go back to main screen.
Good luck
Jan 02, 2018 | GPS
Pioneer GPS - AVIC-S1
Main screen ---Settings ----Keep follow the 1st page, you will see the restored function as Restore Factory Settings.
Apr 13, 2008 | Pioneer AVIC-S1 GPS Receiver
yes..I saw that..need teh model number of the actual gps you are using, please..
Mar 09, 2008 | GPS
Fatal Error Message
I have an older one of these with the AV connections. once in a while it does not see GPS signals. If I exit navigation and from the main menu select setup, I can reset the GPS and then go back into navigation, this seems to cure the issue but it may return. I think the root cause is a low memory battery in the unit.
Nov 08, 2007 | Fine Digital FineDrive 400 GPS Receiver
Intellinav.exe application error
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
GPS Logo
356 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
