I have a wired connection to two computers through a router. My problem is that the router only recognizes one computer. I cannot get an internet connection on the computer in the other room. Please help!
    Genius:
  • 3,587 Answers
The computer in other room...is it connected via cable? if so, look at back of computer where cable is plugged in, and make sure light is on next to cable entry point in back..
do same thing on router..lights should be illuminated.
if not, then cable is suspect.
Posted on Mar 09, 2008
How to configure router to other computer without internet?
For a computer to connect to router there is no need for internet.
If your router is active and functional any computer in its range can be connected with wires by ethernet port or wirelessly with wireless card.
If your computer has wireless card it will recognize the Linksys router and you can connect automatically unless you have a password set for wireless security.
If you need to log on to the router and change settings first step is connect your computer to router wireless or wired then open web browser like Internet explorer or firefox. type 192.168.1.1 this will open a dialogue box for user id and password leave user id blank and type admin in password line. once you are router page you can configure settings on router.
If you need help with setting up router post the question again! good luck
Sep 09, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
Router is recognized but Internet is not
how many computers do you have ?
Is there any other computer online through the router.
If not then make sure that if you connect the computer to the modem, it works.
If it is online through the modem then check the settings of the router...
you will need to connect the computer to the router and open the router set up page.
change the settings on the router.
Click Here for more info
Jan 08, 2010 | Belkin (F5D7230-4) Router (587009)
My N1 Vision router recognizes my modem HUAWEI MT882 SmartAX but does not recognize the connection to my ISP. The modem light is always blinking and can not connect to the internet. What is my problem?
Routers are devices that split Internet connections so that more people can use them. Without them, a modem would have to connect to only one computer. Wireless routersmag-glass_10x10.gif allow computers to connect to the Internet without being physically tied down by the limit of wires, allowing people to enjoy Internet usage anywhere the router has reach. This article will guide you on how to reset or manipulate the settings on a router on any computer that is connected to it.
  1. Step 1 Turn on your computer. Connect to your router by clicking "Start."
    Click "Connect To."
    Select "Wireless Internet Connectionmag-glass_10x10.gif" from the list. At the pop-up window, press "View Wireless Networks." Find your router on the list. Double click on it to connect to it.
  2. Step 2 Click on "Start" again.
    Press "Run."
    At the Run dialog box, type "cmd." Press "OK."
    This opens a command dialog prompt. Type "ipconfig /all." Press "Enter."
  3. Step 3 A list of numbers will appear. These are your currently configured IP numbers, Host computer names, etc. Look for the number labeled "Default Gateway" and write it down. The number is usually 192.168.1.1, or a slight variation of it.
  4. Step 4 Open your Internet browser. Type the number of the Default Gateway you wrote down. If prompted for a username password, the default one for all routers is:
    Username: admin
    There is no default password, so leave it blank.
  5. Step 5 You will now have access to your router settings, regardless of whether you are on your main computer or not. When done, close your browser. Restart your computer.
Nov 15, 2009 | Belkin N1 Vision Modem Router -...
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Internet connection
What is the model or the brand of your modem from Verizon?
Can your computer get online if its wired to the router?
Jul 21, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linxsys wireless modem
Is it working if a computer is wired to the router?
Jun 09, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
