Question about Dell P1130 21" CRT Monitor
Too Bright The front panel (OSD) brightness control is at it's lowest setting and yet the screen is still so bright it's blooming. Cato posted a solution for the Dell P1110 that called for changing a resistor on the CRT controller PCB. That solution worked for that monitor so could it possibly work for this model as well? Thanx dewberr
  • 1 more comment
  • dewberr Mar 11, 2008
    So, does anyone know where to get a schematic for this beast?
    dewberr
  • dewberr Apr 08, 2008
    Regarding March post about Dell P1130. I have the schematic. The voltage at G2 is too high. Which resistors will cut it down and darken the screen?
    dewberr
  • affa Apr 08, 2008
    Viziks,
    I have a IBM P275 and from the schematics it looks almost identical to the Dell P1130.....
    Anyway, for this fix I am looking at R941, would that be correct? any suggested values? Start with 18M and work my way down?
    Champion:
  • 220 Answers
It could.Check the screen voltage G2,If its high more then 400v this fix could work.
Samir
Posted on Mar 10, 2008
  • Samir  Shah
    Samir Shah Mar 11, 2008
    You have to check on the CRT PCB after removing the metal covers which maybe soldered.Normally the pin is labeled G2 and pcb will be cut around this pin to prevent a flashover.Regarding which resistor to change we need to find a schematic to be able to pinpoint which resistor value needs to be changed.
    Hope this helps!
    Samir.
  • Samir  Shah
    Samir Shah Mar 12, 2008
    The schematic is available on www.eserviceinfo.com. Use keywords P1130 and Mfg Dell.
    Please rate my solution.
    Samir.
    New Friend:
  • 4 Answers
Adjust the screen voltage at flyback. Adjust to lower setting until you get the desired brightness.
Posted on May 30, 2013
HP W1707 screen high brightness monitor
the screen is too bright,? ( some models have ambient light sensors) so change that? if there? page 25 read that?
"If you adjust the Quick View, Brightness, Contrast, or sRGB functions in the OSD, the light sensor will automatically be disabled"
i think this is the only post in the world for that. 99.9% is DIM.
circa 2006 monitor, and no HP support
so we go to google ever heard of them?
and bingo 1st hit google, (amazing no>?)
on this monitor. push the menu button (page 30 read/?)
see OSD sure.
the press the bightness , mode using the monitors keys.
then save and exit OSD
end story, same on all monitors, for 20 years.
now the FREE book
https://www.manualslib.com/manual/71492/Hp-W1707.html?page=30#manual
now ive tought how to fish, and spoon fed at same time.
Sep 26, 2017 | HP Computers & Internet
I have a tube tv. the picture as lines and is blur that goes in and out.
If the lines are colored DIAGONAL lines, they are referred to as "retrace lines," which indicates either that the picture tube bias is set too high, or the brightness level is set too high.. If the blur occurs when the image is particularly bright or a particular color is bright, it is referred to as "blooming." This is caused by either a weak high voltage circuit or because the picture tube bias is set too high.
Is the picture set very bright? Try reducing the brightness control to a level where the retrace lines disappear, and reducing the contrast control below the level where the blooming occurs.
If the television is more than ten years old or has many hours of use, the picture tube may simply be deteriorating normally. By nature, they have a limited life span. Before you decide to throw the set out, if you are technically-inclined, try adjusting the bias and screen drive controls for the television as recommended by the set manufacturer (you didn't specify what make or model the set is), and you may get a few months or years of additional life out of the set.
Jul 05, 2011 | Televison & Video
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Nov 18, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
Im a graphic designer and my hp1502 screen is just to bright making me get all my colours wrong ,ive tried adjusting the controls but to nothing works ,is there something in circuit i can adjust to get my...
The best way is through the buttons in front pannel. It will bring an OSD (On screen Display). Adjust the brightness and contrast from there. ( But I guess you have tried it allready )
Then the other solution which i uses to brighten my display is Power Strip.
You can also lessen the brightness/sharpness/contrast.
Chech this link to read about it and a free trial download . Click here.
If helpful, kindly Rate.
Jul 18, 2009 | HP L1702 17" LCD Monitor
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Bright white horizontal stripes - Symphonic 27
YOUR brightness on the high voltage block is too high...turn it down
Dec 02, 2007 | Televison & Video
Tv too bright
This problem might be caused by a problem called blooming. is the picture fuzzy and does the picture look to be streched out. Since you do not have contrast and brightness control this would almost completly point to the HV section of the TV either the control and screen grids of the CRT are going bad or the HV power supply is about to go bad, I would suggest that if you have a background in electronics that you check the HV at the anode of the picture tube and make sure the voltage is from 20Kv to 40Kv using a high voltage probe. You will need a schematic to aid you in your troubleshooting
Nov 07, 2007 | Apex Digital AT2008S 20" TV
Open Questions:
Dell P1130 Blue Channel Problems I've had this monitor for over 4 years now - and it's been going strong since 2002, according to the manufacture date. Over the last year it's health has declined, and the blue channel used to flicker and strobe and pop at me when I switched it on in the morning, but calmed down after a moment and was perfectly normal for the whole day. Recently I turned it on after a couple of days away, and it was yellow - the blue channel didn't even seem to turn on with the rest of the monitor. After trying a few things, including some careful blows from my open hand to the sides, I pulled the plugs out and set it face down on the carpet, and went to find a screwdriver. I cam back, looked at it, and thought - I'd better find out how to discharge the capacitors before I do this. So I set it upright and switched it back on, but this time the blue channel popped on and did it's flickering thing! Almost as though turning it face down fixed it. That state has lasted for a couple of days - and the blue channel has worked ok, but when I switched it on this morning, the blue channel woke up, but then didn't cough into life, so now it's a yellow screen again. I took the back off and vacuumed the dust out, looking for scorch marks and leaking capacitors, but I couldn't see any - my guess is a loose wire leading from the power supply to the electron gun is loose or something like that. I love this monitor a whole lot, and because of it's superior color depth, I haven't wanted to get an LCD until I really had to. What I would like is an explanation of how the blue channel is wired to the electron gun, so I can check for loose wiring, and possibly a leaking capacitor that I haven't noticed yet, as well as the location of the capacitors inside the monitor case. I've been very careful - I've read a few articles on the subject, and I avoid touching anything except the outsides of the case. I know not to mess with things I have little knowledge about. However what I'm looking for is just some information about the blue channel's wiring arrangements, so I can check for loose wiring, or leaking capacitors, or shorted circuit boards.
Nov 23, 2011 | Dell P1130 21" CRT Monitor
Dell P1130 21" CRT Monitor Logo
468 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
