Question about Denon AVR-3600
** SOUND All connections are fine, ** sound from speaker but i do have sound when I connect the headphones.
  • chopperx1 Nov 25, 2008
    i have a denon avr 3600 i grounded the right postive surround speaker wire to the unit and it killed all the power to the unit i check the fuses on the inside and they all were still good i have power to the circuit board but no were else maybe someone else has done this and knows the solution thanks
  • DR1974 May 11, 2010
    please clarify your problem that you are having
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: no sound from right speaker when mp3 connected through aux
Hi bustero78
What happens when you rotate the plug or wriggle it about. If it cuts in and out, then you may have a faulty interconnect lead, or a dodgy socket/plug connection to the player. If it works with headphones, I would suggest replacing the lead.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
  • 7 Answers
SOURCE: No sound from speakers
buttons for speaker no pushed in to turn them on,speakers could be wired wrong to back of receiver
Posted on Dec 14, 2008
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Posted on Feb 23, 2010
Sound comes through only one speaker at a time.
Is the sound on both channels on a pair of headphones? If it is suspect a faulty headphone socket, especially if the speakers are cut out when the headphone jack is inserted - normally.
Jun 15, 2013 | Technics Audio Players & Recorders
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Headphone jack on my compaq presariocq62 is not working
hi
maybe you have loss in jack connection otherwise check sound setting in volume bar right corner of desktop
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
No sound from headphones. Speakers work. Win7
Please clarify, Where is the Headphones connected? Front or back? if you tried it on the Front port without success, Plug in the speaker jack to the port where you did connect the Headphone and verify it's working or not. You can also try the headphone on the port where the speaker is connected.
Awaiting.
Nov 03, 2010 | HP Pavilion m7480n (882780389410) PC...
VIZIO l37hdtv10A, NO SOUND, PICTURE WORKS FINE
if you have headphone connection on tv then try with it.if headphones work that means speakers are faulty.if it doesnt then try with external speakers connection if your tv have one.mostely speakers gets faulty
Jun 11, 2010 | Vizio L37 Television
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Apr 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
No sound coming out of speaker, but headphone jack works!
Hi, I had the same exact problem. The speakers wouldn't work but sound came out of the headphone jack.
To fix my problem, i opened up the subwoofer unit and checked the fuse on the circuit board which seemed fine. Then i had a look at the wiring on the other side of the circuit board and noticed one of the wiring had fried leaving a gap in the connection and exposing the copper wiring. So i just soldered the two bits of wire together. Works fine now!  I just had to be careful when i finished soldering that the exposed wire wouldn't touch any of the other connections. I insulated the wires with a glue gun to keep it all in place.
hope this helps.
Jan 22, 2007 | Logitech X-530 Computer Speakers
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
