Question about Hitachi 46W500 46 in. TV/DVD Combo
Dvd My DVD player won't open at all. I've tried turning the tv off i can hear movement inside but it doesn't come out. what should i do?
I unplugged mine as well, plugged the TV backed in and then hit the open button and it worked. YEAH!!!
GREAT TIP!!!!
Posted on Apr 10, 2008
I had to unplug mine from the wall, then make sure the TV is off, and hit the open button.
Posted on Mar 23, 2008
Dvd player won't play
It sounds that the laser pickup unit of the DVD player have damaged. Check and replace it.
Jan 09, 2013 | RCA TruFlat 27F520T 27" TV
"Loading" screen
time for a replacement .
Jan 05, 2018 | KLH KD1220 DVD Player
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
My CH-300 dvd player's door won't open when I try to insert a disc.
Unplug it for a minute or so. Maybe it just needs to reset.
Dec 01, 2011 | Cyberhome CH-DVD 300 DVD Player
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Dvd player
Hi, where you plug the dvd cables into the tv determines where the picture will be seen; Example, if you plug the dvd players yellow, red & white cable into the tv`s "input 1" then you go to the tv`s "input" or "tv/video" button and push those buttons to get "input 1" to come up on the screen and you`ll see the picture and hear the audio, it`s kinda like a file folder in your computer, you`ve got to find the file then open it to see the contents. If your tv is on channel 3 or 5 or whatever you won`t see the picture because the picture is in video not a tv channel
BMW Rider
Dec 12, 2007 | RCA F20352SF TV
DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Aug 21, 2007 | Mintek MDP-1760 Portable DVD Player
Hitachi 46W500 46 in. TV/DVD Combo Logo
196 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
