98 vw polo random starting problem. It is an automatic... When i shake the gearstick with the ignition fully turned to start ...this used to solve the problem. Some safety device to stop car moving is not switching off. Now the problem has got worse and shakin isnt solving problem. Any theories anyone please?
  • 979 Answers
Will it start in neutral?
Posted on Mar 09, 2008
05 vwjetta 2.0L won't start The fuel pump is good but its not getting any power When we hooked it to a comp it said mass airflow senser, could that keep the fuel pump from working
2000 vw jetta not starting problem solved - YouTube
? 1:56
https://www.youtube.com/watch?v=zvXOynOHywY
Sep 21, 2012 - Uploaded by STF MASSACRE MEDIA
i was on this for days ordered fuel pump accessories i didnt even need and the whole time was a fuse dat regulates to the fuel injectors and gasoline well i ... ... Volkswagen Jetta Won't Crank, Electrical Diagnosis - Part 1 - Duration: ... Duration: 4:05. ...Anyone Have This Problem Starting Their VW Jetta?
VW A3: No Spark Quick Check... - YouTube
? 4:05
https://www.youtube.com/watch?v=X-uxkgveK7M
Oct 7, 2012 - Uploaded by Thomas EXOVCDS
The first part just shows that the hall sensor in the distributor is not. ... VW Jetta No Start - Duration: 4:59. canadacatalyst 51,287 views ... Rabbit & POLO - No Spark at plugs but will bump start - MYSTERY SOLVED! ... VW Jetta won't start? ... 4:05. Ignition Coil Troubleshooting VW 2.0L Golf Cabrio - Duration: ...
VW Jetta No Start - YouTube
? 4:59
https://www.youtube.com/watch?v=eX2lDVCMCNo
Nov 15, 2011 - Uploaded by canadacatalyst
Just go through the basics to see why it will turn over but not start. ... Good diagnosis and repair of catalytic converter on theVW Jetta. ... not start. i believe the fuel pump went bad from sitting long time. no pressure! ... VW Jetta won't start? ... VW A4: 2.0L Replacing Crankshaft Position Sensor / Engine Speed ..
Jan 08, 2016 | Cars & Trucks
Automatic transmission fluid vw polo
The dash lights are powered by the battery through the ignition switch via a fuse. Check the electric connections and conditions of the wires.
Change the transmission fluid to solve transmission issues. Original fluid is always preferable as it is specifically designed for the transmission.
Jun 16, 2013 | Cars & Trucks
The winscreen wipers on my vw polo (51 reg) have started coming on randomly. They then don't turn off until they are good and ready. Embarassing to say the least. What is the likely fault and is it costly?
when you use the washer function of the control arm you also turn on the intermitant wiper function,you need to quickly press the washer setting to switch it off.(bloody clever these VW designers.....)
Aug 20, 2010 | 1991 Volkswagen Fox
1996 vw Polo classic 1.8i delay on activating starter
check for loose starter wire at starter motor large one from batt to post 13 mm socket should do it
Jun 07, 2010 | 1996 Volkswagen Jetta
1999 vw polo starting problem
from your description, it sounds like a bad ignition switch.
Feb 04, 2010 | 1999 Volkswagen Golf
1992 VW Polo 1.3L Coupe: warning light mystery
Bought a very reputable diy service manual for the vehicle, and that plus a bit of thought and nous gave me the cure: no intrinsic problem other than loose relay connections. Went round with the wiring diagrams as guide checking all electrical connections in tight and relays fuses etc all good. Switched on and no problem any more.
By the way, vehicle is 1992 VW Polo - not Fox (which in UK is a variant of the Polo)
Sep 06, 2008 | 1992 Volkswagen Fox
Vw polo 1997 not starting 1.9 d
Check for shorts in the plug wires.
May 06, 2008 | Car Audio & Video
102 people viewed this question
 Grubhead
Grubhead
