Question about Refrigerators
Side by side tilted
Simple problem I want to adjust my fridge so it is level or slightly tilted back so the doors will close by themselves --- possible and how ?
need to know how to take the front cover off safley andjust
    President:
  • Refrigerators Master
  • 2,651 Answers
Bottom kickplate will either just pop off or there will be a ***** or 2 holding it on. you should seee 2 adjustmant *****s behind the plate to raise/lower the wheel assy
Posted on Mar 10, 2008
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
How do i level the fridge?
Use a simple spirit level to incline the fridge a little to the rear as the flow of water to the drain tank and also for the door to close by itself.
There are two adjusters on the front legs and this can be turned up or down as your requirement .
so looking at the spirit level the fridge level can be set and tilted slightly.
Sep 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Fridge door does not close on it's own. possibly missing spring.
There are no springs to assist refrigerator doors to close.
The fridge doors can be made to close themselves by adjusting the height of the feet of the fridge. "Pitching" the fridge slightly away from the hinge will accomplish this. If the foot on the hinge side of the fridge door is slightly higher than the foot on the handle side of the door, the door will usually want to close by itself. If the fridge is a side-by-side type and this is done, one door will close by itself and the other will want to remain open (or open fully). In this case, it's best to have the fridge as close to level as possible.
I hope this was helpful.
Nov 28, 2009 | Amana Refrigerators
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Door will not stay closed
Try tilting the fridge slightly back, or use a spirit level or plumbob at back, non-curved vertical case of fridge to align.
The base should have adjustable feet for levelling.
If tilting forward, even a fraction, gravity will open it.
Dec 19, 2017 | Kenmore 91493 Stainless Steel Compact...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
