Sansui Amp After no use for many years, I'm trying to get my Sansui A909 amp to work. At first it seemed fine, but after very little use it started making a loud pop noise and then nothing. Now it operates for about 10 seconds, POP, and silence. I turn it off and then on again and nothing. If I go back later, it will start up agian and works for about 10 seconds, the the same thing. Over heating? Blowing a fuse that resets?
  • 979 Answers
Bad supply capacitors...accordianman
Posted on Mar 09, 2008
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
Can I connect
Sansui A-80 amp already have the preamp like what
the Sansui C-77 have.
• Sansui A-80 amp could be over-driven with C-77 ,
watch for the volume level.
But you can connect it as an alternate room equalizer
if you need to.
Jul 26, 2012 | Sansui Televison & Video
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to...
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Dec 31, 2010 | Sansui RZ-5200AV Receiver
Mitsi 2004 wont start
Yep, the keys will have what is known as a transponder inside, this transponder sends a signal to a transponder reciever in the column. When the signal matches it allows the car to start.
The system is intergrated into the ECU and cannot be removed, you need the original key to start the car.
Nov 18, 2009 | 2004 Mitsubishi Diamante
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Sansui AU 3900 vintage 1974
Try rick at stereomanuals.com
The shutdown would be from a voltage supply in the power amp seeing too heavy a load and "shutting down" so that the amp doesnt Fry
Feb 28, 2008 | Audio Players & Recorders
SANSUI 218 - 250gb DVD Recorder Black & White
Send it back under warranty -- needs new main board.
Rudolf
Oct 20, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
132 people viewed this question
 Grubhead
Grubhead
