Question about Aqcess Qbe Altus Tablet PC
Bios Battery I am trying to get to the motherbord to replace the BIOS battrey... How do you take this thing appart i took out all the screws, took of the camra, and took out the cd rom... but it still won't come appart! Any help would be hot thanks :)
You need to separate the motherboard from the back of the touchscreen.Don't try to totally disassemble it, just get it to where you can remove the board with the battery.Then you can carefully remove the small board with the battery.
Posted on Apr 08, 2008
CMOS Checksum Inconsistent
This usually occures when the CMOS/BIOS battery is nearly flat. Replace the BIOS battery and go into the BIOS setting to set the Date and Time etc.
Aug 31, 2011 | Toshiba Portege 3500 Tablet PC
I need to reset the bios on my Compaq TC1000. I tried removing the RTC battery and replacing as HP suggested but that didn't work, They then suggested I need to flash my bios. I cant find instructions for...
To flash the BIOS you need to download the BIOS from a link which HP provides.. so contact them and tell them to provide you with the BIOS link..
You need to download the BIOS and install it..
However after removing the RTC battery I would suggest you to hold the notebook power button for 20 secs..
This should remove all the residua power..
I think it will remove the BIOS password...
If it does not work then you could flash the BIOS..
What sayy???
Jun 25, 2010 | Compaq tc1000 Tablet PC
NEED TO RESET BIOS PASSWORD AND / OR WINDOWS PASSWORD
To reset the BIOS password, do the following:
1: Make sure it is unplugged from the adapter.
2: Remove the battery.
3: Take out the 13 screws from the bottom cabinet and lift the cabinet about 1in up.
4: Gently unplug the speaker cable.
5: Completely remove the bottom cabinet.
6: Find the little yellow coin sized battery which is located about 2 inches from where you plug in the power adapter.
7: Unplug the coin sized yellow battery.
8: Pump the power switch a few times to discharge what little charge may be remaining in the computer.
9: Plug the coin sized battery back in.
10: Flip the computer over and plug it in to your power adapter.
11: Turn it on and start pressing F2 - the CMOS settings (including the password will have been reset.
12: Press F9 and then enter.
13: Enter the correct time/date.
14: Press F10 followed by enter and it will reboot without a "BIOS" password stored.
For a windows password recovery there are a few programs that can do the job. I personally like "ophcrack". It is freeware that you can easily find using google.
Hope that helps
Jan 15, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Got lifebook second hand its a p1120 i need to reformat windows but cant acsess bios i need to change password can u help
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 19, 2009 | Fujitsu LifeBook P1120 Tablet PC
Need bios password for fujitsu siemens v2055
bios password can only b reset by removing the c-mos battery...Try to goto boot in last known good configuration option in safemode....if it doesn't boot den install a new os..
May 20, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
How to remove cmos battey to rest bios in hp 2710p laptop
Go on your manufacturer's website, find the maintenance manual, find where is located the battery and just remove it for a few seconds it may remove the password on your bios. Good Luck!
Mar 23, 2009 | Compaq 2710p Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Reset the bios on a compaq tc4200
I haven't tried it yet, but according to HP's "Maintenance and Service Guide" (Available in PDF from their Support website) you have to completely break down the computer, remove the mainboard and the CMOS battery should be located on its underside. Remove it for five minutes, replace and reassemble EXCEPT FOR BATTERY and turn it on under AC power only. I just purchased one that needs reset, but haven't received it yet, so I cannot attest to its effectiveness except that this is deirect from HP. Hope it helps!
Nov 26, 2008 | Compaq tc4200 Tablet PC
Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Nov 10, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Aqcess Qbe Altus Tablet PC Logo
83 people viewed this question
Top Aqcess Tablets & eReaders Experts
Marvin
Marvin
Are you an Aqcess Tablet and eReader Expert? Answer questions, earn points and help others
