Tv repair I have a rca mdl HD50LPW42 tv that has a small 3/4 inch piece of glass in fron of the colour wheel that is cracked...this crack is on the picture at all times...Can this be replaced with just ordinary glass or do i need some special glass for it.? thanks
  • 1 more comment
  • pitchd Mar 09, 2008
    That sounds good to me but the original glass did not break like tempered glass breaks (small tiny pieces) It came out in two cleanly broken pieces which seems like ordinary glass...Can this be try...thanks
    Thanks for the help...
  • katcee May 21, 2008
    Lamp went "pop" and upon removing it, I too noticed the cracked heat shield glass in my set before the color wheel (?). Can't help but wonder if it's not the culprit behind the dark, translucent ~6" corner on the the top left of the tv screen. Any luck replacing it?
  • 979 Answers
Use tempered glass for undue stress and heat that may be encountered...accordianman
Posted on Mar 09, 2008
  • Michael Borelli Mar 09, 2008
    Ordinary glass may be used, but I believe that this is what caused the original to break...accordianman
Cracked screen
    wholesale lcd 1024x600 ips 7 - AliExpress.com
    www.aliexpress.com > Wholesale Product
    7" 7Inch 1024*600 1024X600 IPS TFT LCD Dispaly Screen For ... 100% Original LCDScreen Replacement Repairt Part For Freelander PX1 1024X600 IPS Screen ... Original New 7" IPS Tablet Touch Screen Touch Panel Digitizer Glass For ... images for Cracked screen 7 inch panel 1024x600 ips
    More images for Cracked screen 7 inch panel 1024x600 ips
    Cheap screen 1024x600 replacement tablet 7 deals
    guide.alibaba.com > Computer Hardware & Software > Tablet PC
    7 inch 1024*600 IPS screen Capacitive touch panel nfc android tablet .... Front TouchScreen/Panel Glass Screen Replacement Repair Parts for RCA Tablet 7 ...
    Touch Screen 1024x600 - Alibaba
Jan 01, 2016 | Tablets & eReaders
How to stop cracks in winsheild
Clayton, a small crack say 2-3 inches may be fixable by glass shops injecting a filler. If about 6 inches, replace the windshield because it will get larger and unsafe. Yes it will cost you insurance deductible but that's life. My windshield was cracked 6 inches by a golf ball, can you imagine? Had to change.
Jul 28, 2013 | Building Materials
I have a sumsung 50" DLP. After grinding, cracking, and popping it stopped working. I opened up the side compartment to change the bulb. Bulb is intact but there was broken glass that I couldn't tell where...
if the bulb is ok your colour wheel is broken you must open up tv take out engine kleen all glass and replace colour wheel this repair will cost about 200 dollar
Jul 28, 2010 | Samsung HLN5065W 50" Rear Projection...
Cracked LC37D62U LCD TV
It is broken,The outside is a Polorised film.Like window tint,It is repairable,New LCD screen.But may be cheeper to buy a new TV. GET A EXT.WARENTY!!! will not cover accidents but the new tv's do break alot,and are expensive to repair.
Buy a name brand, NOT RCA "junk" Just a name
no longer a company. Samsung,Panasonic,Sony. If you want to support the USA buy another Sharp. Still a great TV. And made in America. NOTE they make after market screen protectors. GOT KIDS? GET ONE. :) Or even a piece of plexie glass if cash is tight. Hope this helps.
Oct 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
RCA HD50LPW42. Sound so loud it sounds like a jet engine coming from TV (very loud whining sound). I assume this is my color-wheel, but I'm not sure.Turns off when TV turns off.
You need a replacement color wheel or have yours rebuilt since the RCA color wheels are on nationwide back order. You can get your wheel rebuilt at the following link
http://servicemanuals.vstore.ca/
Sep 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Bose Acoustimass 15 woofer, Replacement of RCA female connector
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Dec 11, 2008 | Bose Acoustimass 15 System
The lamp on my Samsung HLP5085 burned out last night with a loud pop. I followed online instructions to remove it and orderd a new lamp. Then, I noticed that a small 1"x1" piece of glass...
It's doubtful that buying a new color wheel will solve that cracked glass problem. However, if you are going to buy a new color wheel you may as well purchase a new television as they are extremely expensive and most new units do not use them. I suspect the piece of glass may be protecting the lamp from anything on the inside of the TV or preventing anything from getting to the color wheel so it may work out just fine the way it is. I would suggest reporting back after you have replaced the bulb. In other words, don't order anything else just yet.
May 06, 2008 | Televison & Video
Cracked glass on front glass
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
Nov 05, 2007 | Televison & Video
Color wheel and lens
if u are not a technician, better have it check by a qualified one. because doing so might create more problems. service center have special tools and equipment for aligning and replacing these stuffs. just concern
Jan 14, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
