Question about Maytag Neptune FAV6800AW Top Load Washer
Matatg Washer Model PAV2200AWW
During the spin cycle the drum wobbles so badly it causes the whole washer to vibarte and move violently.
  • jcmmaltman Apr 14, 2009
    When the washer goes to spin cycle the washer wobbles drastically and moves all over the room to the point someone has to sit on the washer to keep it still. PAV2200AWW Maytag Performa washer
  • Anonymous Mar 15, 2014
    wobble becomes violent when motor speeds up Model number 23022101
There is no display screen on this unit probably the self adjusting legs on back not working properly or the gasket that it sits on is bad
Posted on Oct 20, 2008
  • 96 Answers
Sounds like you should be getting a UC display that would indicate an out-of-balance condition. If it's not happening then you're either not getting a signal from the tub position sensor located near the front of the tub because it broke off or is faulty.You should check this first.
Posted on Mar 11, 2008
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
The washer shakes violently and crawls forward - so far forward as to unplug itself. Help !
Sounds like a broken damper.
The drum assembly inside a front loader is noramlly supported by two or more big springs on the top, and two damper units underneath. If either or both of the damper units fail, the machine will still work but when spinning, the drum assembly will be able to move excessively causing serious vibartion - as you describe, quite often the whole machine leaps about !
If your comfortable working on washing machines, and can get hold of spares for your machine, then it isnt too bad a job. Otherwise, call an engineer !
Sep 22, 2009 | Samsung WF337AA Front Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
315 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
