Pioneer SG-9500 Equalizer Power Led Replacement?
Pioneer EQ needs a new power led light.
Can not find any anywhere. Pioneer part number AEL-063
  • 979 Answers
A generic LED will work just fine. Be sure to match polarity...accordianman
Posted on Mar 09, 2008
Hi,It is not an led just looks like one from the outside,if you gently pull it out from the black rubber block you will see that is a 8volt incadescent at 50 milliamp rating,on ebay cheap!
Posted on Dec 12, 2010
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
My pv231 eq just stoped working, the led light is not coming on, what could be the problem? pls help!!
Most common problem is power cord works loose. Beyond that it may be a pwer supply failure.
Apr 13, 2011 | Peavey Pv231eq Dual 31 Band Graphic...
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
How should i hook up a pioneer sg-9500 EQ to a pioneer SA7500 and a TX 6500 tuner and amp
check in yhe back of your amp to see if you have a pre amp power amp rca jumpers. If you do. remove these jumpers and take the pre amp out and plug it into the eq in. Then take the eq out and plug it into the power amp in. this will put your eq inbetween the pre amp and power amp. If you don't have these rca jumpers on the back of your amp, you can do the same with your tape record in and out inputs on back of amp.
Nov 13, 2009 | Audio Players & Recorders
Jun 25, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
May 19, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
575 people viewed this question
