Question about Dishwashers
Door Lock/Champion Dishwash Model #UH-150B
Hi:
While this unit is running the handle/lock unlocks and the machine will stop. What part do I need to replace to repair this problem?
Thank you.
PaulJan
C
    Genius:
  • 1,554 Answers
Most folk will just replace the door locks .
but a tech needs to check the secure connnection of the wiring to both the lock and the circuit board, and to look at the bottom of the circuit board to be certain of ** cracks on the relay solder joints as is the usual issue, sometimes its the relays themselves that have pitted contacts due to all this intermittent issue.
Posted on Mar 10, 2008
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
Message code DL F???
Hi, this is a Door Lock Failure Error.
The service manual lists the following causes:
Door Lock Mechanism is broken or removed from door.
Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this).
To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Jan 08, 2011 | Kenmore Washing Machines
I get an error of f 29 and my door won't unlock
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Front loader door unlocks during cycles with door lock light on.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 15, 2009 | Kenmore Washing Machines
TUW model - not cleaning fully, top sprayer does not spin
make sure the wash arm holes arent obstructed and the wash arm seams arent cracked.
Sep 17, 2007 | Champion 24 in. UH-150B Built-in...
My model Num. is TUW - 70
It indicate there is a live ac leakage on the chassis.it is very dangerous if you don't have any electric knowledge.don't touch it again.switch off the main supply and contact the service technician for help.
Aug 22, 2007 | Champion 24 in. UH-150B Built-in...
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
