All my DVD-RW disks come out marked "read only" and I can't save to or drag files to those disks.
  • tdouglas Mar 09, 2008
    Every time I reformat a DVD-RW disk and attempt to use it for backup of files and folders, it comes out Read Only.
    Genius:
  • 3,587 Answers
Tdouglas...that's a settings issue on the software you're using....what are you using for windows..it can be set through the control panel and device manager.
Posted on Mar 09, 2008
  • 796 Answers
Hello
  • isaac johny
    isaac johny Mar 09, 2008
    may be the life time of the dvd have reached....
    how much times have you written in it??
I am able to burn the DVD-RW, but then I cannot add to the disc with any more files. I was told not to "close" the disc, but I see no such option popping up. I just drag the docs to the disc,...
I am not sure about the MAC, but the PC's have the choice to save like a CDROM or like a DISK, or something similar to this. Using CDROM closes the drive after burning, the other choice will allow you to add files.
Oct 19, 2017 | Memorex (32025536) DVD-RW Storage Media
My sony blu ray drver not play blu ray dice only
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver
http://download.cnet.com/sun-cd-dvd-burner/3000-2646_4-10308060.html
Sun CD/DVD Burner can back up data on CDs and DVDs, store large media files, and compile music CDs. It can burn and save whole ISO files, as well as create multisession CDs and erase rewritable CDs. Sun CD/DVD Burner supports almost all kinds of driver types including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB). The program also supports the ability to drag and drop. Version 3.10 may include unspecified updates, enhancements, and bug fixes.
What
Jul 31, 2011 | Sony BD-5300S-0B 12x Internal BD-RW...
I have an ACER Extensa 4220. My OS is Windows 7 Ultimate 64-bit. My problem is: After OS installation the CD/DVD drive is working well--able to read disc in general, able to install softwares or driver via...
Purchase a new (or used) disk-drive that is compatible with your Acer notebook.
Remove the current disk-drive, and set it aside.
Connect this "alternate" disk-drive, and install Windows onto it.
Then, test the CD/DVD drive -- if it still gives problems, then you have a "hardware" problem with the CD/DVD drive, and trying to make any "configuration" changes within Windows will have *NO* effect.
Jun 01, 2011 | Acer 4220-2346 Notebook
When trying to save a file on a "read/write" disc
you will have to burn this file to cd\dvd rw disk
hope this helps
Nov 22, 2010 | E-Machines emachines (emachinees) CD-ROM...
Which dvd disks do I buy to burn a dvd on my optiarc dvd rw ad 7563a ATA Can I add later batches of pictures? can I reuse the DVD disks?
DVD media has several types:
* DVD-R ("write-once-read-many")
* DVD+R ("write-once-read-many")
* DVD-RW ("write/erase/rewritable")
* DVD+RW ("write/erase/rewritable")
* DVD dual-layer ("write-once-read-many")
Some CD/DVD-writing software allows multiple "sessions" (write a bunch of files, do not "close" the disk, much later write a bunch of files), so that you can "add" files to an "open" ("non-closed") CD/DVD disk.
Jan 24, 2010 | Gateway (5500652) (  5500652)...
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
Nov 07, 2007 | Roxio Easy CD & DVD Creator 6...
Laptop CD/DVD Drive
In order to copy files to a CD like a hard drive you need a program that can treat the CD like a hard drive. Sometimes called *drag and drop or drag to disk*, is this what you?re using and if so what program are you using?
Mar 31, 2007 | Toshiba Satellite A105-S4004 Notebook
Televison & Video Logo
Top Televison & Video Experts
