RCA Proscan TV
I have a older model 32in RCA proscan with the control panel on top of the TV. The circuit board under the cover of the control panel is bad, how do I find that board?
The board number is 1531178c, this board controls the on/off, volume, channel, menu, and remote sensor.
Any help you can give me would be great.
  • 979 Answers
I am so sorry, but that board is Way out of production. You might try service forums for Thompson or Proscan. What kind of problem is there with the old one?
Posted on Mar 09, 2008
Proscan tv pled1526a powers on but shuts off after blue proscan screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 23, 2016 | Proscan Televison & Video
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ...
    www.shopyourway.com > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    https://www.youtube.com/watch?v=TC908vQ8jaw
    Jan 17, 2013 - Uploaded by ShopJimmy.com
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
Proscan led 39" tv no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions
May 21, 2015 | Proscan Televison & Video
50" proscan led tv new main board but still same issue....
Check whether the control voltage comes to the inverter section cirlcuit at its power board; from the main board. There is a control voltage that controls the light intensity; as well as start, of the inverter section circuit at the main power regulator [SMPS]. It should come from the main board. It this voltage is absent, the main board is faulty. Check whether it is present or not. It will be best to contact any service technician in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 02, 2015 | Proscan Televison & Video
Have a proscan tv dvd combo it turns on has sound but no picture
Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel.If so, they can't be replaced.In this case; a panel replacement is the only repair.For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS].To such sets, the power supply section circuit too should be troubles hooted.Contact any service technician.The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Feb 25, 2015 | Proscan 32LB30QD 32 in. LCD TV
Why won't my Proscan PLDV321300 TURN ON ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 08, 2014 | Televison & Video
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
