Question about Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher not washing very well
The dishwasher is not cleaning consistently. When I open the door mid cycle the water is hot and coming out of the arms but the arms are not spinning (not sure if they should be or not). The arms do move at some point as they are not in same position as they were at the start. The water is pumped away at the end and the remaining (very little bit) is clean. I've checked for bits in the arms and they are clean and have run 'dishwasher cleaner' products through the machine. Any ideas - does this sound expensive to fix? The machine is a integral Neff 4.5 years old.
  • 1 more comment
  • Lin999 May 08, 2008
    Yes I have the same sort of problem. The top shelf crockery seems clean but the dirtier things on the bottom- pans, cutlery and roasting dishes etc., that used to be cleaned perfectly, are now coming out almost as soiled as they went in. I also have cleaned all the filters and the spray arms and have run two dishwasher cleaning products through on the hottest, longest setting with no improvement. The spray arms are working well and the water heats appropriately, as I also checked mid-cycle.A plumber friend also cleaned out the inlet hose for me last week as no water was coming in then either.He solved that problem but I am still left with bad cleaning.
  • Weasel007 Sep 04, 2008
    I have a similar problem. All feeds to the arms are clear and both arms spin freely. The upper arm is intermittently fed with water pressure, whilst the lower one is fed all the time. I'm wondering if there are seperate pumps for the upper & lower arms. Any ideas? .
  • CPAJP Sep 05, 2008
    I have exactly the same problem. I have changed the upper and lower spray arms so there are definitely no blockages there. The problem remains. The unusual thing is that it is inconsistent as occassionally everything washes well.
Hi i have a neff s5433xogb/13 and the top arm does not rotate,i have checked for any blockage and cleaned it all out any ideas please
Posted on Jan 10, 2011
  • 117 Answers
There are several things you can do to make sure your dishes are clean. I recommend following these 8 steps in my FAQ http://tclaundryrepair.com/ and your dishes will always come out clean
Posted on Feb 20, 2009
    President:
  • 1,462 Answers
Usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Posted on Jun 19, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Dwu7400aax - dishes do not come clean eough
make sure you water is hot enough, manufactures reccommened 120 degrees to the dishwasher, i advise all customers to run hot water at sink til you get hot water then turn dishwasher on, also fill both compartments of sopa, also use rinse aid or jet dry, do not use gel packets. use cascade powder or liquid only.also run the unit through a clean cycle this should be done once or twice a year. letdishwasher fill with hot water. when starts to wash, open door and add 2 cups of white distiilled vinegar and close door and let it go throughas cycle. no dishes. also i reccommened dish majic cleaner sold at walmart or grocery stores. if this dont help then youw wash syatem could be bad or going bad.hope this helps you. try all these things first befor you re[lace uniy or pay to have it looked at.
Sep 17, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Neff 24 in. S5443X2 Built-in Dishwasher Logo
531 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
