Sony TV snow at startup
1994 model Sony KV20S10 Trinitron Color TV has s**w and ** sound at startup on all channels and after undetermined time will come on with perfect picture and sound quality. If turned off/on the problem again starts. The TV is operated on locl antenna (rabbit ears) and the menu is set to "cable-OFF". One suggestion on this site advised using a straightened out paper clip inserted into cable connection on TV and have TV menu set to Auto Programming to see if any channel would appear, **ne did as there was ** change in the problem. Any suggestions?????
    Genius:
  • 1,694 Answers
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Posted on Mar 10, 2008
Why does a Sony Trinitron when on Video 3 works fine with dish. When on channel 3, color goes to b & w, then snaps back to color. on a regular cycle ?
your converter box has a channel generator for the channel #3 and you tv has a tuner set to ch#3 that and a coax wire . every part of that system has to be working correctly to send video ,color,sound if even one part of the system is a little off you run in to problems . most likely your problem is with the converter box channel generator . contrast that to when you get the signal from your video input . with that simple system you just take video from the video board in the box and send it directly into the video board in the tv .....a lot less to go wrong .
Aug 26, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
When I turn the tv on (vega fd trinitron) the scren is all snow. There is no signal.
Hello
Have you tested it with auto tuning progremme process. If it snow there, your TV may be working properly. Sometimes its signal input path is not Ok. Without any signal, all TVs may show either snow, or a plane blue raster if its blue back function is on. You just do the automatic tuning process once again after connecting it with an external or internal antenna. There is a socket provided there in the back side of your TV, and marked as VHF/UHF. Connect the signal source to it first.
And set your TV to autotune by slecting it from the menu of your TV. The TV will search for all the channels available at that time, and after searching is completed, it will stop and show the first channel received. Afterwards you can chage or delete or skip unwanted channels. You may have its manual with you. All the descriptions are there in that manual. Ok.
Oct 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
Sony tv
Please resold all pins of IC001 in main board of TV. Problem will be solved.
Aug 08, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
KV35540 Sony Trinitron
pls check the antina or the cable line or the cable plug or call the tech.
in the tv tunner foulty
Jun 07, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Bad reception on lower channels
Hello Moeggy,
Tuner of your TV set got defective and need to be replaced. Pls contact nearest Sony service shop for replacement of Tuner.
May 08, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV is cutting in and out of color
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Mar 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv repair
Your tuner (in the tv menu) is probably still set on "cable", but it should be set on "off air" or "antenna". When you first turn it on, it looks for a cable signal and when it can't find one, it automatically searches for an "off air" or "antenna" signal. Once it finds a signal, then it stays on and runs ok. If you shut it off, then it has to go thru all this again.
There is a very high probability that this is your problem (about a 99.99% chance). Just go into your menu and select "tuner" or tuning or "input select" or something in that "neighborhood". Different TVs call it different names, so just put in on the option other than "cable". If you ever get cable back again, then, of course, you have to go back into your menu and set the tuner to "cable. Hope this helps.
Keever
Mar 08, 2008 | Televison & Video
32" Sony Trinitron made 10/1994
Probably bad solder connections in the video processor area.
Oct 29, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
