Question about RCA Lyra RD2765 MP3 Player
Rca mp3 file system corrupted
This mp3 says file system corrupted when i turn it on and my computer wont recognize the mp3 when i plug it in
  • 4 more comments
  • Anonymous Mar 29, 2008
    my mp3 says please upgrade how can i upgrade it?
  • Anonymous Apr 12, 2008
    it says file system corrupted and computer not reading it either
  • Freddie T Apr 25, 2008
    When I try to turn on the MP# player it says "Hard disk temperature too low!"
    Now what do I do?
    I already uploaded the updates and this happened.
    Can anyone help?
  • Anonymous May 23, 2008
    i have the same proble when i tunr it on says file system corrupted and my computer doesn't reconaize
  • eehj May 23, 2008
    ihave the same problem turn it on says file system corrupted and my computer doesn't reconaize
  • Anonymous May 29, 2008
    1. my rca h115a says i have corroped files when i turn it on
Throw it to the floor. I threw it three times and started running.
Posted on Apr 19, 2009
  • 34 Answers
This is the message that the player gives when the hard drive fails. You can try upgrading the firmware.
Go RCA at the following link and download the 'hard drive upgrade utility'
http://support.rcaaudiovideo.com/downloads.aspx?product=202
When ready turn player off then press and hold the center toggle while connecting the USB cable.
Run the install program.
If the player still fails and you want to save it contact Sansaworld.com, They can replace the hard drive with flash memory. The player will load faster with 4x the battery life.
Posted on Apr 09, 2009
When i turn on rca h125 mp3 player says file system corrupted
Posted on Jun 16, 2008
Throw it out and get a newer beter one
Posted on May 26, 2008
How can i get my mp3 unlocked
Posted on Apr 24, 2008
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
Oct 14, 2009 | RCA Lyra RD2763 MP3 Player
Rca mp3 opal
your boot file is corrupt so it wont boot u will need to use a computer to format it. plug the mp3 player into ur computer go to my computer right click the mp3 player and select format. Format will wipe everything off ur mp3 player
Jul 15, 2008 | RCA OPAL M4001 MP3 Player
Rca mp3 player h125
plug it into your computer and re-format it
Jan 24, 2008 | RCA Lyra RD2765 MP3 Player
My RCA LYRa is having issues!!!
http://www.fixya.com/support/t126039-file_system_corruption
(H115A)
Had "File System Corrupt!" message appear on my RCA H115A after a bit over a year. PC wouldn't recognize it, and it wouldn't stay turned on.
Following advice (thanks folks), I uncovered the screw under the barcode and popped the back with the help of my knife. I didn't notice that the connection from the hard drive was loose, but pulled it out, wiped everything off, and reconnected. It worked!
They don't give this at the help desk, but it seems to be a common problem with many models. Looks like the connection isn't very tight.
Jan 05, 2008 | RCA Lyra RD2763 MP3 Player
Rca H125PA mp3 player
I had the same problem and went through RCA support to get a solution which (to my surprise) actually worked. Here's what you need to do. Connect your USB cable to your computer but do not connect to your mp3. Hold down the toggle switch on the mp3 while turning it on. Then insert the other end of the USB cable to the mp3. This should allow your computer to recognize the mp3.
Now go to website: support.rcaaudiovideo.com (no www. prefix). Go to "software updates". Click on "mp3 players" a couple of times and then your model "H125". Then click on "H115 and H125 Lyra Hard Drive Upgrade Utility" and follow the directions from there.
Jerry
Nov 13, 2007 | Audio Players & Recorders
Mp3 Player "File System is Corrupt"
The below was copyed from an earlier post of mine. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Aug 19, 2007 | RCA Lyra RD1072 MP3 Player
RCA H125 File System Corrupted
I've had this problem twice now and fixed it once. I'm in the process of fixing it again. Here's what you do, and this is a slow process so have some patience with it. Hook it to your computer then power it off. When you power it back on, with the cord still connecting it to the computer, hold down both the front buttons and the power button. You should now see it saying connecting. It will take a LONG time for your computer to recognize the device and give you access to it in My computer. Once it does, you can then remove the file system and replace it.
Jun 07, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
RCA RD2762B problems "File System Corrupted"
I just bought this item today and had the same problem! JUST GOT IT! BUT! i fixed it! Open it up there will be a hardrive take the hard drive out by lifting a little black flap where it connects and reconnect it it has to be reconnected the right way so take ur time make sure ur doing it right then when u reconnect it there is a very small black flap where u connected it psh that down tight! It worked for me :)
Apr 15, 2007 | RCA Lyra RD2765 MP3 Player
System file corrupted
ok my mp3 doesnt work and i held down the joystick whats the problem i mean my computer still cant find it and it still says file systems corrupted
Apr 11, 2006 | RCA Lyra RD2765 MP3 Player
RCA Lyra RD2765 MP3 Player Logo
344 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
